7 members (Steelonsteel, J Lucas, Wayne67vert, Shade Baby, rfs56trk, greenie-reddy, 1 invisible), 79 guests, and 4 robots.
Topics128,269
Posts1,058,399
Members48,485
im about to shorten a long bed to a short bed on my 66. i feel as tough i might have better luck by doing it with the bedsides off. i know they are just bolted on the end closest to the cab, but what about the tailgate end?
Well, from what I saw on a TV show, the tailgate and back stake rack housing is kept intact. I believe they cut out a section about a foot in from the back. It looked pretty straightforward as I remember. They didn't take the bedsides off probably for stability. Don't konw how they did the frame.
sovagary
GS
The show was Trucks! on Spike. They cut the frame under the cab, forward of the rear trailing arm mounts.
Bill Burmeister
To remove a bedside, you unbolt the front panel and all the bedwood attached to it and the wheel tub. The rear cross sill has a couple of bolts inside that needs to be removed and then you need to cut the small welds in the corners to get them apart.
Good luck,
Scott
Scott Ward
2 1948 1.5-ton Loadmasters
1 1950 3100
1 1955.1 Chevy 6500
1 1954 Chevy 6500 2-Ton
1 1955 1st Series COE 5700
1 1963 K20 (454)
1 1964 C10 (350)
1 1951 1.5-ton Dump Truck
1953 and a 1956 Ford F800
cool i figured there would be some welds that would have to be cut. i saw that episode on trucks so figured i would give it a try, i found a long bed as straight as can be for 80 bucks so i thought it would be worth a shot......ill keep yall posted thanks again
