1 members (Samantha),
45
Mod | | | Forums66 Topics128,179 Posts1,057,159 Members48,465 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | | | | | | Joined: Nov 2007 Posts: 131 Certified Bolt Nut | | Certified Bolt Nut Joined: Nov 2007 Posts: 131 | How much for you to do mine?? 8-) | | | | | Joined: Sep 2007 Posts: 2,644 Shop Shark | | Shop Shark Joined: Sep 2007 Posts: 2,644 | That's what I call dedication! How much for the CAPs coating? | | | | | Joined: Sep 2006 Posts: 2,393 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 2,393 | Thay look great! I am afraid my silver Hot Temp spray paint on mine looks rather lame compared to yours.
Drew
| | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | Very nice!
Bill Burmeister | | | | | Joined: Feb 2005 Posts: 338 Shop Shark | | Shop Shark Joined: Feb 2005 Posts: 338 | The Cermakrome was $110.00 for the pair. If you consider shipping (NY to CA) and tax I believe the whole thing was about $180.00. sixtyfive c-10, I don't think I would do it again.  It would be interesting to hear from others if you have to go as far as I did to get a nice finish. The ceramic coating must smooth out the surface some. I think CAPS said the 220 grit finish would produce a very smooth result. I could have cut 3-4 hours of sanding time if I had quit there. | | | | | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | Bill,
They look like liquid gold. Did you have the flanges milled down to match the intake manifold flanges in thickness?
Stuart | | | | | Joined: Apr 2004 Posts: 888 'Bolter | | 'Bolter Joined: Apr 2004 Posts: 888 | Bill, They look great!! It shows you put some time into. When the weather cools up here......You gotta have something to do! Dan | | | | | Joined: Dec 2004 Posts: 1,897 Shop Shark | | Shop Shark Joined: Dec 2004 Posts: 1,897 | I had mine done locally at Sanderson's Headers. It cost $175 for the pair, and they did the sanding.  | | | | | Joined: May 2006 Posts: 166 Wrench Fetcher | | Wrench Fetcher Joined: May 2006 Posts: 166 | Nice job. Mine are on order. I asked that they be Jet-Hot coated. I am sure they won't be that nice, but I am anxious to see them.
Todd | | | | | Joined: Nov 2004 Posts: 2,422 Former Workshop Owner | | Former Workshop Owner Joined: Nov 2004 Posts: 2,422 | Great looking job Bill! I am very familiar with various plating techniques and applications, but not cermakrome coating. I am curious as to how that will hold up to the high heat from the exhaust. I am going to ask the local plating shop if he can do that. I will probably never have enough money in my old truck budget, but I really like how yours turned out.
That is very cool. Once again, GREAT JOB!!!
~ J Lucas 2006 GMC Envoy 4.2 I6 2023 Ram 2500/Cumins 6.7 I6 2010 Jeep Grand Cherokee (Wife’s) 2002 Silverado 2500 Gas 6.0 1941 Chevy 1/2-Ton 1942 Chevy 1.5-Ton SWBIn the Gallery My Flicker Photos! | | | | | Joined: Feb 2005 Posts: 338 Shop Shark | | Shop Shark Joined: Feb 2005 Posts: 338 | Here is the link to CAPS info. They advertise in the inliners newsletter. http://www.capsbhc.com/coating1.htmI'm certainly jealous of $175.00 and no sanding. I did fit the headers with my intake manifold before I started the sanding. I made final adjustments on the tabs to get the retainers even. Dan, I'm hoping to get bed wood for Christmas  | | | | | Joined: Aug 2007 Posts: 1,859 Grumpy old guy playing with trucks, cars, and boats | | Grumpy old guy playing with trucks, cars, and boats Joined: Aug 2007 Posts: 1,859 |
| | | | | Joined: Dec 2005 Posts: 1,026 'Bolter | | 'Bolter Joined: Dec 2005 Posts: 1,026 |
Robert C. If it's true what they say, "You learn from your mistakes," I'm a Genius in the making. 1950 3600 | | | | | Joined: Jan 2005 Posts: 279 Shop Shark | | Shop Shark Joined: Jan 2005 Posts: 279 | Looks really good Bill!I had caps porcelinize mine,it was $300 a pair
Gangster whites and straight pipes.....
| | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | What did you or they do about the sealing surface? And when you porcelinize them how do you keep from cracking the porcelin when you tighten the clamps? Denny G
Denny G Sandwich, IL
| | | | | | Dave Giorgi Unregistered | | Dave Giorgi Unregistered | Nice job Bill, they look great. Send a post when there installed. | | | | | Joined: Jan 2002 Posts: 866 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 866 | Wow, those look great. Nice work!! | | | | | Joined: Feb 2007 Posts: 385 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2007 Posts: 385 | Nice job. Mine are on order. I asked that they be Jet-Hot coated. I am sure they won't be that nice, but I am anxious to see them.
Todd Would you mind posting a picture of yours when you get them? I was hoping for a set of Fentons for Xmas, but got a 'Honeydoo' list instead.
195? Chevy 3800 dump truck 1973 Chevy C30 cab and chassis 1987 Suburban 3/4 ton 6.2L Diesel
| | | | | Joined: Dec 2002 Posts: 571 Shop Shark | | Shop Shark Joined: Dec 2002 Posts: 571 | Super Sweet! I have another project to add to my list now. :crazy: | | |
