Labor Day
Labor Day
MORE wrenching?
Wrenching this Labor Day
Plenty of places to share.
1 members (baldeagle), 62 guests, and 2 robots.
Topics128,009
Posts1,055,293
Members48,419
#346592 12/09/2007 3:38 PM
Anyone ever used one of THESE? or THESE?
Woody
Your Brother in Bolthood
My 1951 half-ton 'Ol Red
Door Art Collection
Czechman #346628 12/09/2007 5:04 PM
no but i got one in the barn,still in the box. bought it at a swap meet for $25.00.figured when i get my engine built i"ll have the shop bolt it to that so i can haul it home easier and be able to roll it out of the way til i get ready for it....dave
1949 Chevrolet 3100
"When this thing hits 88 miles an hour, you're going to see some serious sh%t." -Doc Brown
i have a friend that has one, pretty flexable but works ok. i made two for inline sixes out of the base of a industrial banding machine. they work great and you don't have to worry about lining up the motor mount position bolts it just tightens up with some long 1" threaded bolts with plastic caps on the ends.
No, but hopefully I will pull my (400 miles since overhauled) '57 235 next week and will need a resting place for it in the bed of my F*&D pickup for the trip back to the remanufacturer. I say hopefully because I have been truly bummed since completing this restoration and discovering that something is just not right with the power plant. Viejo has been sitting in the garage looking good. Just don't go judging a book by it's cover.
Any suggestions?
Don
My 1941 in the Stovebolt Gallery
My Photo Album
But I tried, didn't I? ... At least I did that. RP McMurphy
The past belongs to the future...but only the present can preserve it.
Besides the noble art of getting things done, there is a nobler art of leaving things undone.
down2sea #346889 12/10/2007 4:57 AM
I'm going to swing by Northern Tool tomorrow and pick one up. Although theirs is made for an SBC I'm sure it can be modified simply for an in-line 6.
Woody
Door Art Collection
down2sea #346892 12/10/2007 5:03 AM
I built my own for a spare 292 that I have. It looks similar to one of those, a little lower and narrower. I have a problem with it. I went to put a set of long tube headers on it, so I could mock up power steering on it and the headers don't clear. Trying to design one that is narrow, low, and have the headers clear isn't easy. I may just go back to using an engine stand. I may just cut down and engine stand.
Larry
I don't own a vehicle that isn't old enough to drink.
LGriffin #346947 12/10/2007 1:27 PM
2 Offline
I have the one from Greg Smith. I got it because it will fit any engine without any modifications. I haven't put my spare engine on it yet but it looks like a sound unit for the money.
Tom
dgiorgi
Unregistered
dgiorgi
Unregistered
Hi, I have always used old shopping carts with the top of the cart cut off. If you have a welder, you can make some brackets to weld to the frame to bolt down the engine. I never needed to weld anything to the carts as they seem to cradle the engine pretty well as they are. Just a cost effictive suggestion especially if you have more then a few engines laying around.
#349270 12/15/2007 11:45 PM
I have the $29.00 type with a 250 on it, works just fine. I also have several shopping cart specials that I have modified with mounts and they work fine too. I also have a GMC 248 with Hydramatic attached sitting on a 2" X 4" frame with a plywood floor and some unknown source casters that works O.K. too. Whatever you use will be fine just to make moving an engine around.
chevman32 #350346 12/19/2007 2:27 PM
dgiorgi
Unregistered
dgiorgi
Unregistered
Hi, those front wheels are unboltable on the shopping carts which I have also used to put everything in my garage on caster. When cleaning or just to rearrange things around the wheels are priceless. I even have my metal lathe and band saw on wheels. As you get older and with my son now gone, putting things on wheels really helps out alot.
#350983 12/21/2007 4:14 AM
I finally got fed up trying to get those cheap Chinese cradles to work so I made one out of wood and Home Depot casters for $25.
Picture It works very well. Very stable and rolls fine with 3-inch casters but would roll better with 4-inch.
Woody
Door Art Collection
Czechman #351076 12/21/2007 3:52 PM
That really looks pretty good! I like it.
I took different approach to my V8's because I have so many. I went to Tractor Supply Co. and bought a bunch of furniture dollies and threw a tire on top of them. I set the engine on top and the tire forms around the engine and holds it upright. Tires work good for transporting an engine in the back of the truck.
Last year, I knew a auto scrap yard owner that was going out of business and bought 15 or so adjustable engine dollies. I got to pick the ones with the best casters and I had to pressure wash them off. Now I just need to get them under all my engines. :/
Builder #351102 12/21/2007 5:01 PM
Nice job Woody! Being a woodworker by trade I respect your skills. I made mine using 2" square stock. Didn't finish my cradle as you can see in pic below. Pieces laying on transmission were supposed to fit under bellhousing. Someday....
Dan
http://rides.webshots.com/photo/1512705220071274430hzqWNh
Chev4t6 #351123 12/21/2007 6:23 PM
Nice job,where theres a will theres a way.
dale937 #351138 12/21/2007 7:19 PM
It almost looks too nice to get oily! That's real pretty.
Builder #351185 12/21/2007 9:38 PM
Very nice and it will never rust!!
Wanted Good Woman:
Must be able to cook , clean , sew , tune engines and polish trucks. Must have old Stovebolt and garage. Please send picture of old Stovebolt and garage.
Chev4t6 #351300 12/22/2007 3:25 AM
grin wave
Woody
Door Art Collection
Czechman #357426 01/07/2008 2:54 AM
Woody, nice cart.
I have one I build out of 2x4's and casters similar to a furniture dolly. I use that for small engines (Currently have an Audi V6 on it). I also have an engine/trans dolly I made years ago out of inch and a half channel that has an adjustable rear cross member so it fits engines and trans from V6's to Big Block Olds.
I also used a creeper once with a chunk of plywood on it to not puncture the padding.
Either way, buy one, or build one
Scott
Moderated by  MNSmith
