2 members (qside, 78buckshot), 76 guests, and 1 robot.
Topics128,072
Posts1,055,907
Members48,429
#346660 12/09/2007 5:55 PM
How big of a problem are the Hydro-Vac systems? I have one off my 1954 parts truck and was thinking of putting it on my 1954 1 ton. Would it be worth while or just something else to mess with? ohwell
Bruce
My Trucks
Stuff I Collect
Bruce,
The system itself is trouble free and simple. It's self contained and requires only vacuum plumbing and some brake line plumbing.
My question would be, do you need the extra oink on a 1 ton. Aren't the brakes the same physical size for the smaller trucks as the 1 ton.
The 1 1/2 ton, with dual tires and a much higher GVW would require the extra help of the Hydro-vac, where the 1 ton probably was fine with the conventional master cylinder. My three cents!
Stuart
atomarc #346715 12/09/2007 8:22 PM
I don't know, I've never used this type of system. I have the dumb thing and thought it might be cool to have it on the truck. I'm already putting a 261 in Big Orange which has the dual rear wheel option. We go from just under 3000' to over 7200' here in the Black Hills area and I just wondered if it might help with stopping. I'm unsure if I will ever really work the truck very hard, depends how nice the restoration comes out. I guess it would be another toy on my truck. grin
Bruce
My Trucks
Stuff I Collect
My 1953 Chevrolet
1947.1 Gallery
Perfect! Thanks for the link. grin
My Trucks
Stuff I Collect
Bruce,
You probably are aware of this, but the Hydro-vac unit is a "power assist" only. It reduces the amount of peddle pressure the operator needs to develop. It doesn't make the brake system anymore efficient. Because it is easier to mash the brake peddle, it might give you the reverse effect which would be more brake heating and more chance of fade.
Stuart
Riding in the Passing Lane
They are good but sometimes they are too sensitive. If someone goes to drive it that is not used to it they will be all over the windshield.
1972 Chevy c10 Cheyenne Super
What makes you think I generous enough to let somebody else drive my truck! So what I'm hearing, unless I plan on heavy loads...probably not a good idea? grin
Bruce
My Trucks
Stuff I Collect
My truck has the hydro vac system, first old big truck I have ever had. But I have had and still have several antique vehichles, the 47 has the best brakes of any antique I have ever had.
My 1958 1 ton dually came with a Hydrovac. It is listed as an option in the owners manual.
Considering that I need a new master cylinder, and the hydrovac likely needs rebuilt, and the stock setup is a single reservoir brake system, I was considering going with a new fangled dual reservoir, power assist brakes. Probably save money, probably work better, probably be safer.
