2 members (fonz8261, TrknGMC), 226 guests, and 4 robots.
Topics128,074
Posts1,055,999
Members48,433
i read recently from someone on another forum discouraging the use of the conversion kits for the 64-66 c-10s that utilize the later model saginaw power steering box with a special bracket that is drilled and installed on the frame. its a pretty popular conversion for these years trucks and many companies provide these kits. has anyone ever run into any problems with these conversions? the guy was saying that they prevent full turning potential on one side. just wondering if anyone has any warnings for me before i go ahead with it thanks, murdoc
Murdoc,
I did one about 6 months ago on a 65 C-20. It is alive and well and have had no problems. Follow the directions for the conversion & line everything up and I'm sure it will be fine.
Fred
Riding in the Passing Lane
I did one on a 60 panel a while back. The 60-62 is more difficult then the later ones but it worked good. If his was out of center he had the wrong piman arm or the tie rods were out of adjustment.
1972 Chevy c10 Cheyenne Super
ya, this guys post was the first negative statement that i had ever heard about the conversion so i wanted to make sure.
anyone know how well this setup fairs against the factory power assisted steering that originally came with these year pickup?
Much better. The old original system used the control valve & ram. It was troublesome & didn't give a quicker ratio.
i see, this guy wants to sell me one of those setups for $100. i wasnt sure if it was worth it......
I built my own kit and used a steering box I already had. The only thing to watch out for is, I got a real tight ratio and it's a little touchy to drive, real sensative. I ended up liking it once I got used to it,
Scott
Scott Ward
2 1948 1.5-ton Loadmasters
1 1950 3100
1 1955.1 Chevy 6500
1 1954 Chevy 6500 2-Ton
1 1955 1st Series COE 5700
1 1963 K20 (454)
1 1964 C10 (350)
1 1951 1.5-ton Dump Truck
1953 and a 1956 Ford F800
As Scott mentioned there are gear boxes with different ratios.
I used the one that had about 4.1 turns which I think is standard.
The other one that I am aware of has about 3.6 turns, it might be a little too quick for most uses.
Fred
