11 members (Eisenholtz, Gone, Peggy M, Donf, Otto Skorzeny, Wickedbass, Hawkman, NJC, GRNHydra, hdgeren, 1 invisible),
72
Mod | | | Forums66 Topics128,023 Posts1,055,370 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2007 Posts: 25 Apprentice | | Apprentice Joined: Nov 2007 Posts: 25 | i wasnt shure where to post this so i did it here.i was just wondering if someone could explane to me how the foot starter in these trucks work?and any info i would need to know when i put it back together? | | | | | Joined: May 2005 Posts: 334 'Bolter | | 'Bolter Joined: May 2005 Posts: 334 | When the foot starter is pressed, it, via the linkage, closes the contacts on the starter switch that is mounted on the top of the starter, energizing the starter and engaging its pinion with the flywheel. There's not much in putting it back together - you just want to make sure the switch on the starter is in good condition and that the linkage engages it properly. Samantha | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | Just to add to this, the starter pinion is mechaically engaged by the linkage. You can actually feel it engage pack through the pedal, then when the peasal is pressed a bit further, it closes the contacts to energize. Also, on 12 volt trucks ('55-59 w/6 cylinder) it also energizes the resistor bypass to feed 12 volts to the coil for startup.
Bill Burmeister | | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | It's also a good theft deterrent because most people don't know how to start a stomper.
| | | | | Joined: Nov 2007 Posts: 25 Apprentice | | Apprentice Joined: Nov 2007 Posts: 25 | thanks guess it seems pretty simple,but what about the key? | | | | | Joined: Jul 2000 Posts: 579 'Bolter | | 'Bolter Joined: Jul 2000 Posts: 579 | The key simply turns the ignition on. Another nice thing about this arrangement is that you can spin the engine (like for a compression check) without turning the ignition on (if you don't have a bypass wire between the coil and starter, that is).
| | | | | Joined: Jan 2005 Posts: 1,602 Shop Shark | | Shop Shark Joined: Jan 2005 Posts: 1,602 | I agree with the "theft deterrence" point. When I first got the firetruck, I didn't know what it was. I'd turn the ignition and figured it just wouldn't start. My Dad had to tell me about it. That was embarrassing.... | | | | | Joined: Mar 2000 Posts: 1,177 Red dot, center of chest ... | | Red dot, center of chest ... Joined: Mar 2000 Posts: 1,177 | First time I took my truck to the local oil change place, they had no idea how to start it. They had to come and get me. They were all amazed when I turned the key, stepped on the starter and the truck fired right up.  | | | | | Joined: Jul 2005 Posts: 1,158 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 1,158 | First time I took my truck to the local oil change place, they had no idea how to start it. They had to come and get me. They were all amazed when I turned the key, stepped on the starter and the truck fired right up.  I have a funny foot starter story... My mom's family is populated with gearheads, and one of her cousins has a 1936 Plymouth Business Coupe with a foot starter. One day last year, it started hailing, and two of my uncles (the oldest and the youngest) decided they'd do Jim a favor and put his Plymouth in the garage. The younger uncle was going to put it away. They sat there and sat there, and I finally went out to see what the problem was. My uncle rolls down the window. "It's not turning over!" I ask, "Are you using the stomper?" He replies, "Yeah... See?" I lean in and look to see what his foot is doing... ...And I can't believe that my older uncle (who is sitting in the passenger seat) didn't say anything. "Uncle Gary," I said, trying not to laugh, "That's the dimmer switch."  At least he knew there WAS a stomper.  | | | | | Joined: Jun 2000 Posts: 454 Shop Shark | | Shop Shark Joined: Jun 2000 Posts: 454 | First time I took my truck to the local oil change place, they had no idea how to start it. They had to come and get me. They were all amazed when I turned the key, stepped on the starter and the truck fired right up.  In cases like that, it's even more fun to get in the truck, turn the key to on, hold both of your hands over the dashboard, and say "Start, truck" while hitting the starter with your foot. Some of the expressions you will see are priceless. A downside of not telling a shop how to start the truck is that they can twist the ignition key until the ignition switch or key breaks.
Jeff Nelson
"Beer is proof that God loves us and wants us to be happy." - Benjamin Franklin "Always do right. This will gratify some people and astonish the rest." - Mark Twain
| | | | | Joined: Mar 2007 Posts: 4,215 Moderator | | Moderator Joined: Mar 2007 Posts: 4,215 | When we were little, my dad forgot to turn the key on his car. The stomper didn't do squat so we kids all had to push it down the road. It wouldn't push start either. It finally dawned on him that the key wasn't turned. | | | | | Joined: Mar 2005 Posts: 284 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 284 | I think I have the only 8 year old(daughter by the way) that knows how to start a truck with a foot stomper. She just loves it! | | | | | Joined: Sep 2007 Posts: 75 Shop Shark | | Shop Shark Joined: Sep 2007 Posts: 75 | A lady told me that her first car was a '41 Studebaker. The salesman started it up and then let her drive it. She agreed to buy it and he delivered it to her where she was going to beautician school. The car was running when she went to it so she slid in, drove him back to the dealership, and then drove home and turned it off. Next morning she got up to go to school and couldn't find a starter button. Finally called the salesman and he came over and showed her the starter button under the clutch pedal. | | | | | Joined: Oct 2006 Posts: 289 Shop Shark | | Shop Shark Joined: Oct 2006 Posts: 289 | I took my truck to the local oil change place one day since I was in a hurry to get out of town. Since there is no filter or wiper fluid, etc, I tried to negotiate a better price but they wouldn't budge. When the kid trying to move it in asked if it was an automatic, (its 3 on the tree) I began to have visions of a ruined flywheel if he found the stomper. I volunteered to move it in, but they said that was against regulations so I took it home and did it myself and saved some cash, plus who know what else. | | | | | Joined: Oct 2007 Posts: 52 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2007 Posts: 52 | I live in canada and we have to go through aircare to get our anual insurance...The kid blew my 3 speed tranny trying to get it up to 60 kmh in first then trying to get it in second on a dyno...he thought it was an auto too cause the shifter is on the colum... well 1500 bucks later I uped my Gvw to 5500 kgs and Now I dont need aircare...problem solved.. James | | | | | Joined: May 2006 Posts: 77 Shop Shark | | Shop Shark Joined: May 2006 Posts: 77 | When I convert to a small block in my 55 2nd series, do I need to by a different set up to maintain the foot starter? Personnally, I like the foot starter and would like to maintain that set up.
Admin for Turbobuick.com 87 GN, and new toy: 1955 Chevy 3200 pickup, soon to have: 383, Cola crank, Childs/Albert 6 inch rods, Brownfield heads, 10:1 KB hypers, CompCam 284 Extreme Energy, Tilton Plate transmission realignment and built Turbo400.
| | | | | Joined: Apr 2005 Posts: 2,097 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,097 | You won't be able to use the foot starter with the V-8 as it is not compatable. When I did my V-8 conversion I fabricated a plate to hold the starter pedal in the original location. It still gets noticed and people ask what it is. Fred
| | | | | Joined: Mar 2004 Posts: 3,068 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 3,068 | When I convert to a small block in my 55 2nd series, do I need to by a different set up to maintain the foot starter? Personnally, I like the foot starter and would like to maintain that set up. You could mount a push button starter switch like tractors have under your stomper somewhere under the hood so it will actually be functional. I would think it would be a simple fab job to get going, Scott | | | | | Joined: Jul 2005 Posts: 1,158 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 1,158 | You could mount a push button starter switch like tractors have under your stomper somewhere under the hood so it will actually be functional. I would think it would be a simple fab job to get going, A couple of the guys here have done just that. The starter Button switches are available at your FLAPS. Do a search of the forums to find out how they did it. I'm using a starter button for my horn, as it's wired in straight through, and I kept burning up horn buttons.  It doesn't happen any more!  | | | | | Joined: Nov 2007 Posts: 25 Apprentice | | Apprentice Joined: Nov 2007 Posts: 25 | would the 216 foot starter linkage be the same as on a 62' 235 belaire | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | No. Cars didn't use the foot starter after '48. And trucks stopped after '59.
Bill Burmeister | | | | | Joined: Nov 2007 Posts: 25 Apprentice | | Apprentice Joined: Nov 2007 Posts: 25 | do you know if it would be possible to rig it up to work or is it completly different set up?
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | 53chevyman,
Are you asking if a foot-starter mechanism from a 1953 216 could be used on a '62 (Belaire) 235 mounted in a 1953 truck?
Tim | | | | | Joined: Nov 2007 Posts: 25 Apprentice | | Apprentice Joined: Nov 2007 Posts: 25 | yeah, i saw a good engine for sale and i want to switch to a full pressure 235 but keep the foot start(its one of my favorite things)but if i cant then ill just keep looking for a truck engine with a 235 in it | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | As long as you used the belhpusing from the 216, and perhaps the flywheel as well if you keep it 6 volt, then yes, it will bolt up. The linkage actually mounts to the bellhousing rather than the block.
Bill Burmeister | | | | | Joined: Nov 2007 Posts: 25 Apprentice | | Apprentice Joined: Nov 2007 Posts: 25 | K thanks thats what i needed to hear | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Someone will correct me quickly, I hope.
You might have to put the correct (216-truck-style) front motor mount on the 235.
Put the 53 truck 216 pressure plate, clutch assembly, and bell housing on the 62 (Belair) 235.
Mount the 53 foot-starter assembly on the 53 216 truck bell housing.
The 53 truck 6v starter will work fine.
Someone, please quickly correct me if I am wrong.
Tim | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | I think you've got it covered. I forgot about the front mount.
Bill Burmeister | | | | | Joined: Nov 2007 Posts: 25 Apprentice | | Apprentice Joined: Nov 2007 Posts: 25 | yah thanks for all the help,i didnt want to go into it blind,ive decided to buy the engine and just do what you guys said to do,Longbox you said that i need to keep it six volt,just wondering why and if i could use some kind of volt reducer,im just asking cause the 62's a 12 volt and i was doin the switch anyhow,but ill keep it six if i have to. | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | The 6 volt starter will be fine on 12, it doesn't run long enough to really make a difference (besides, it'll actually work better on 12!! ), I only mention it because of the flywheels. There is a difference in the tooth spacing between the 6 and 12 volt flywheels and the corresponding starter drives. As long as you use matching parts (6 volt starter with 216 flywheel or 12 volt starter ('55-'59 truck for stomper) and 235 flyhweel) you'll be just fine. Either way, you will want to use the 216 bellhousing and fron plate.
Bill Burmeister | | | | | Joined: Oct 2001 Posts: 3,458 Extreme Gabster | | Extreme Gabster Joined: Oct 2001 Posts: 3,458 | Some of the '54 and up truck bellhousings I've seen still have the flat spots on the top of the bellhousing for the stomper linkage to mount, but you need to drill and tap for the crossover bar mounts. It should be easy.
