0 members (), 135 guests, and 2 robots.
Topics128,080
Posts1,055,954
Members48,430
#342128 11/27/2007 5:41 PM
Cam
Offline
So not realizing that my hinges were in fact great shape, I took the approach of cutting the hinge pin between the bracket and hinge...worked great to get the pin out but distroys the pin. Now for the irony, you can't buy replacement pins OF THE SAME SIZE. You can buy oversized but it pains me to redrill and take the chance of screwing up the alignment. Anyone have or know where I can get an original pin for a 54 1st series 3100??
thanks in advance-
cam
Cam
An amateur expects things to work, and is surprised when they don't; a professional expects things to not work and is surprised when they do."
1954 Chevy 3100 1st Series in the Gallery
More at my Picasa site
If no one has a couple for you, I would suggest having a machine shop turn you a couple. I suspect it would not be hard. If you work where there is a machine shop perhaps you know someone, or know someone who knows someone else, and get them to cut you a couple on their lunch break. Most companies don't mind that as long as it don't get to be a habit.
Cam
Offline
Hmmmm, good idea! thanks-
cam
Cam
Z
ZooKeeper
Unregistered
ZooKeeper
Unregistered
Z
Look at the hinge pins on the S10 doors. They may work properly once you cut them to lenght & if they are too big around at least you have something to start w/to machine down. If you want one to see shoot me a PM w/your address & I'll send you one....Joe
#342738 11/29/2007 4:55 AM
Cam
Offline
ZK- thanks, I do already have the oversized so yea, I've got something to work with, i will check out the S10 in the hopes they are the same circumfrence.
cam
Cam
