3 members (TUTS 59, Bill Hanlon, Jon G), 97 guests, and 5 robots.
Topics128,121
Posts1,056,328
Members48,439
#34162 09/03/2003 8:43 AM
Hi Everyone,
What's the best sounding mufflers for a 235 inline 6 with dual exhaust? Also who sells a dual exhuast kit?
TIA,
David
My truck don't leak oil, it just marks its teritory.
#34163 09/03/2003 1:06 PM
Patrick's is coming out with a stainless steel system in November or so. Also Jim Carter sells the pipes and you add the mufflers. Heard that Flowmasters sound the best but depends on what kind of sound you want and whether or not your state lets you install round glasspack styles or that they have to be oval. Smithies supposedly sound good too. There was a previous thread on this about a month ago. wink
Country Roads, West (By God) Virginia
http://community.webshots.com/user/geezer
#34164 09/03/2003 1:54 PM
1953 Chevrolet 1300 - Daily driver
Collecting Vintage Whizzer motorbikes
http://www.whizzerick.com
#34165 09/03/2003 5:11 PM
Mufflers are kinda like toothpaste; they all do the same job, it's just a matter of what flavor you like. grin
1955 First Series GMC 250 1-Ton Panel
Mr. Hedgehog - Follow the build
If you can't laugh at yourself, I'll laugh at you.
#34166 09/03/2003 5:36 PM
Let me tell you my revised plans for my 292.
I'd initially decided on dual Flowmaster 40 series DeltaFlow mufflers all the way out to 2" tips. Then I thought about the resulting sound and the cost. To achieve the deep near v8 sound I wanted I would have to have a balance tube or crossover pipe added to help blend the exhaust notes. That would only add to the $300+ tab for the cost of the Flowmasters.
I decided after listening to some online sound bits of straight sixes with true split dual exhaust that I did not want to go that route. I hated the sound. Not the deep tone that I wanted but very much "six-cylinder like", if that makes sense. So I decided that off the headers I would have the exhaust connected by a 'Y' pipe into a single Flowmaster muffler. The Flowmaster I've chosen has a 3 inch inlet and dual 2 1/4 inch outlets. I plan on finishing the exhaust from the muffler back with 2 1/4 inch diameter pipes all the way out.
I'm dropping the engine in this weekend. Everything should be finished by mid-month. I'll post pics and let you know how it sounds.
-ftyler
#34167 09/03/2003 5:44 PM
I love my Smithy's. The best part is the I6 sound. It doesn't sound like a V8 cookiecutter conversion.
54 3100 with 235
62 flatbed dump C60 with 261
#34168 09/04/2003 4:36 AM
I've been thinking of dual fentons into a 2 in 2 out muffler. Seems like that would be compact and serve the purpose of the balance tube too. Anyone heard of doing that? The 2 in 2 out are somewhat unusual but I have seen them.
Dennis
40 Chevy 1/2 ton
#34169 09/04/2003 6:27 AM
That dual inlet outlet muffler should work for a balance tube if it is designed right. It could be two separate mufflers in one case. I think the two into one with one tailpipe one would be the best set up. The dual tailpipes might not have enough heat to keep them dry. Could be prone to rust out. The exhaust gas is already cooled by the time it hits the muffler so one 2" or 2 1/4" tailpipe would be plenty. You could always add a 4" fart can like all the imports are running grin .
#34170 09/04/2003 12:50 PM
Dennis; At this time, Patrick's is going with a stainless steel system with a dual in and out muffler. The outlets will come back to the rear on one side and sit "shotgun" style. I think that this might be what you're thinking of. There is a picture of the muffler in their latest catalog.
#34171 09/04/2003 1:47 PM
Did any of you notice the tailpipes on the woodie in the above Smithy ad?
#34172 09/04/2003 4:00 PM
Hey Joe H,
Using aluminized tubing would eliminate the rust through problem for good. That's certainly what I plan on using to finish out the exhaust on my '66.
-ftyler
#34173 09/04/2003 6:50 PM
A BMW muffler assembly from a '88-91 325i might work well. It's dual in/dual out, has built in tips, shotgun style, and is straight and flat. It also has plenty of flow and sounds good. It's already designed for a straight six.
Paint & Body Shop moderator
#34174 09/05/2003 1:45 AM
My dual pipes get plenty warm.
Hey, how much for the BMW muffler?
54 3100 with 235
#34175 09/05/2003 6:53 PM
About $150, I think.
#34176 09/05/2003 7:12 PM
That is probably the chrome tip, I mean the whole muffler. grin
54 3100 with 235
#34177 09/05/2003 7:15 PM
I love my dual smittys comeing off of the fenton headers,,,just a real good tone in my book, but then to each their own,,,,Fred
Redryder pix
My Hotrod
#34178 09/05/2003 9:54 PM
Ansa muffler Ok, so that was a little more than I thought. $192.96 from alloembmwparts.com. It comes with pipes and hanger already welded up. It's a nice piece, though. I have had mine in and out of my car a few times (you have to to change the clutch/driveshaft), and it's quite well made. Mine is still good after 13 years and 150,000 miles.
