2 members (Don88, Nick in Manitou), 111 guests, and 2 robots.
Topics128,162
Posts1,056,936
Members48,458
#341449 11/25/2007 5:23 PM
The original ball collar torque tube seal was a felt packing between two steel washers. I have a Felpro replacement gasket set and the seal is rubber instead of felt. It is about 1/4 inch wide and 1/8 inch thick. Are the steel washers still supposed to be used with the rubber seal?
I believe so. Those washers squish the gasket tight to make it not leak and retain the gasket in the collar without displacing it.
Jeff
My 1953 Chevrolet
1947.1 Gallery
I thought so too, but using them doesn't allow the collar to thread all the way up on the ball collar tube and it leaked badly. I'm thinking that the washers may be distorting the rubber gasket.
Oh, you mean theyre not supposed to leak??? grin
Mine drips a little and I just figured it was because it was old and worn. It seemed to make more sense to use the steel rings in there. I thought tightening would displace the rubber and push it out of the collar if I didnt use those rings. One thing I noticed was the old seal was quite a bit thicker then the replacement. That may have something to do with it as well. :confused:
Jeff
My 1953 Chevrolet
1947.1 Gallery
When I took mine apart (49 longbed so I had two of these set-ups), the seal was cork between the two steel rings. My replacement seal was rubber and I installed it between the two rings. No leakage and everything snugged up tight. I got my kit for my longbed from American Classic and everything in it worked well. Perhaps the kit you got came from some substandard manufacturer. Think I took some pics of the kit when the assembly was all apart on the workbench.
http://community.webshots.com/user/geezer
Country Roads, West (By God) Virginia
