4 members (Wayne67vert, delky, Peggy M, 1 invisible), 83 guests, and 2 robots.
Topics128,060
Posts1,055,839
Members48,427
#340685 11/23/2007 10:21 PM
getting ready to pull the motor and tranny out of my 51 gmc. Can anyone give me a run down on the freeing them from the torque tube. It looks like it unscrews from itself.
southerncharm #340707 11/23/2007 10:55 PM
Unbolt the 4 bolts that hold the ball collar to the tranny, slide it back, slide the ball cover back and that will expose the u-joint. It has lock plates that youll need to pry away to remove those bolts and then the yoke can be slid into the torque tube further and dropped to the floor. Be careful with the torque tube as they are heavy as hell! Its a good idea to support it before dissassembling the parts.
Jeff
My 1953 Chevrolet
1947.1 Gallery
rustednuts #341164 11/25/2007 12:58 AM
You might want to loosen the knurled collar thats at the rear of the ball housing. This will make it easier to slide the unit back.
1949 Chevy 1/2-Ton
"Sedgewick"
1989 Caprice
