| | | Forums66 Topics128,064 Posts1,055,861 Members48,428 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2007 Posts: 19 New Guy | | New Guy Joined: Mar 2007 Posts: 19 | getting ready to pull the motor and tranny out of my 51 gmc. Can anyone give me a run down on the freeing them from the torque tube. It looks like it unscrews from itself. | | | | | Joined: Feb 2006 Posts: 1,867 Shop Shark | | Shop Shark Joined: Feb 2006 Posts: 1,867 | Unbolt the 4 bolts that hold the ball collar to the tranny, slide it back, slide the ball cover back and that will expose the u-joint. It has lock plates that youll need to pry away to remove those bolts and then the yoke can be slid into the torque tube further and dropped to the floor. Be careful with the torque tube as they are heavy as hell! Its a good idea to support it before dissassembling the parts.
Jeff | | | | | Joined: Dec 2003 Posts: 2,953 'Bolter | | 'Bolter Joined: Dec 2003 Posts: 2,953 | You might want to loosen the knurled collar thats at the rear of the ball housing. This will make it easier to slide the unit back. | | |
