6 members (Jay R, Otto Skorzeny, Bill Hanlon, rick46ia, TUTS 59, 1 invisible), 53 guests, and 3 robots.
Topics128,023
Posts1,055,366
Members48,420
Apprentice
Apprentice
I have a 53 Chevy 1 ton and with the colder weather the speedometer jumps up and down. A friend says the cable needs lubed but I think the problem is in the speedometer head itself. All sugestions appreciated, Thanks
Ex Hall Monitor
Ex Hall Monitor
Could be either. You can lube the head using some sewing machine oil (air tool oil will probably work OK too). Close to where the cable attaches there should be an recess with a small opening at the bottom. There is normally some fibrous (cotton?) packing exposed by the opening. I've been told that this is where you are supposed to lube the head by putting a drop of the oil in the recess which is then wicked up by the packing. I've used a small syringe to shoot oil into the packing with some success. While you're doing that you can lube the cable too. I use white lithium grease on mine. Good luck.
Might also be the speedometer gear. I just changed the sm465 in 68 C20. The speedometer needle was jumping around and I figured it needed rebuild. Since I changed the trans the needle no longer jumps around. 8-) The old trans had 125k miles on it, afaik it was original trans.
Larry
I don't own a vehicle that isn't old enough to drink.
I find that when my speedo starts jumping or sticking in the cold weather, loosening up on the retaining nut on the back of the speedo solves the problem many times. Funny things happen on mine when that is too tight.
Ex Hall Monitor
Ex Hall Monitor
Funny things often happened to me when I got too tight as well. grin grin
My kinda guy Tiny grin..... I go along with the need to clean and re oil the cable advice.
Leo Offline
Moderator
Moderator
I had a jumpy speedo years ago in the winter. For me, it just was part of the car's character. On the warmer days, it was fine again.
I think sometimes frost gets into the cable and makes them act up when it's cold. And I'm sure it doesn't help if it's a little dry to begin with. So probably try lubing the cable, as others have suggested.
Rich
1947 Loadmaster
1947 Chev. Loadmaster
1959 Chev. Viking 40
definatly the cable grease is hardening up in the cold...try light oil
7
7 Offline
The speedometer cable in my truck jumps around accompanied by a clicking noise. I asked my brother how to fix it and he told me to clean it good and lub it with trans fluid.
The truck has a two piece cable so I will try cleaning and lubing the upper one first and see how it turns out.
Danny
