0 members (),
196
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,081 Posts1,056,078 Members48,434 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2007 Posts: 33 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2007 Posts: 33 | I have a 1954 Chevy 4500 short bus. The hydrovac underneath was disconnected when I bought it. Without power assist, one really has to stand on it to stop. I really don't know much about hydrovac's. It appears to have a steel tank underneath that is part of it. I have seen dual master cylinder, power brake units for the smaller chevy trucks on EBay. Could I ditch the original hydrovac and use something like this?
I am sure that the hydrovac needs rebuilding. I like keeping things as original as possibly with the exception of 1 things, the brakes.
Has anyone upgraded the front brakes (discs, dual master with power assist on a big bolt?
Or, might it be better to use a more modern hydrovac off a newer bus? (I would have fabricate brackets, etc. of course)
Thanks | | | | | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | Well first it is possible to rebuild your hydrovac and its not real expensive.
Upgrading to a dual master and vacuum or hydralic power can be done and I believe the same brackets as the smaller trucks will do it, though sizing the master cylinder might be different.
I don't know if newer buses use hydrovacs or not.
As for disks on a big bolt, I'm not aware of anyone who has done it without also changing the axle also.
Search for posts by Grigg and his axle replacement story. His approach is probably the high end way to get it done, but proves it can be done effectively.
1955 1st GMC Suburban | 1954 GMC 250 trailer puller project | 1954 GMC 250 Hydra-Matic | 1954 Chevy 3100 . 1947 Chevy COE | and more... It's true. I really don't do anything but browse the Internet looking for trouble... | | | | | Joined: Mar 2004 Posts: 3,068 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 3,068 | I have a dual res master and booster under my trucks floor. I fabbed my own bracket to mount them to. I can't remember exactly which booster I used but it was from a mid 70's GM product. The master is a 1970 C10 from a drum/drum system. I use this truck to plow with and usually have about 4 tons of gravel loaded on for traction. This brake set up has more stopping power than any other big bolt I've driven and they're easy to apply, maybe a little too easy, but I like them. Scott | | | | | Joined: Sep 2007 Posts: 33 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2007 Posts: 33 | Great. Thanks a lot for the help, Scott. | | | | | Joined: Sep 2007 Posts: 33 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2007 Posts: 33 | Thanks a lot for the help  | | | | | Joined: Feb 2007 Posts: 190 Shop Shark | | Shop Shark Joined: Feb 2007 Posts: 190 | My 47 had the same thing, hydrovac was not connected. Brakes worked but like you said it took real effort and they were scary,Had the hydrovac rebuilt + rebuilt all the brakes. The brakes work quite well, I only have the one reservor, I know it would be better to have two. But the brakes are the best working brakes I have ever had on any antique vehicle I have ever owned. This is my first truck larger than a half ton though. | | | | | Joined: Sep 2007 Posts: 31 New Guy | | New Guy Joined: Sep 2007 Posts: 31 | My 53 had a hydrovac setup similar to the one you're describing. Instead of re-building it, we decided to upgrade to a dual master cylinder power brake system. The donor cylinder and booster came off of an 81 1-ton Chevy Suburban. We wound up fabricating a bracket and mounting it on the frame in the same general location the old master cylinder was. The only real issue was that we had to make an access panel in the floor to get to the cylinder to fill it with fluid and the inlet sizes for the brake lines on one side of the cylinder were different than the other. However, after we got those few minor kinks out, it brakes extremely well and we're happy with it. If you'd like any pictures of the set up on my truck, let me know through private message or e-mail and I'll be happy to send them to you. Good luck! | | |
