2 members (wilbur53, Bill Hanlon), 137 guests, and 3 robots.
Topics128,196
Posts1,057,387
Members48,471
Apprentice
Apprentice
This is mounted on my '49 3100 (new to me). i know it's not original. No numbers on it anywhere I can find. It is leaking a little and i would like to replace it.
pic here
One day I would like to go to a dual, but if I can rebuild this one or get a rebuilt cheap I may go that route for now.
Scott
1949 5 Window 3100
3B Offline
Hy Meyer, it looks like a master cylinder from an early to mid sixties Dodge 1/2 ton, hope that helps.
It's not that much more work to swap it out for a dual master cylinder.. i'd just do it..
Another quality post.
Real Trucks Rattle
It looks like the one off of my old 63 Impala,
Scott
Scott Ward
2 1948 1.5-ton Loadmasters
1 1950 3100
1 1955.1 Chevy 6500
1 1954 Chevy 6500 2-Ton
1 1955 1st Series COE 5700
1 1963 K20 (454)
1 1964 C10 (350)
1 1951 1.5-ton Dump Truck
1953 and a 1956 Ford F800
it kind of looks like an old-school hydravac.
It's definitely a MoPar pickup M/C. My 65 Dodge 1/2 ton had two, one for the brakes, and another one without the brake light switch for the hydraulic clutch.
Looks like several upgrades to your fine looking '49. Do you have a swing pedal now for that master cylinder? As was stated, a dual cylinder is an easy switch.
Drew
1 Offline
look again real close for casting # if you find any go to the bendix website and that usually will id. a mc. or wc.
UPGRADE!
~Jim
Apprentice
Apprentice
Found the casting number on the bottom. Late 40's to early 50's Dodge/Chrysler.
It does have a swing pedal.
Just going to replace for now. May do an S10 frame swap down the road (probably heresy to some here grin ) so will just do the whole upgrade at that time.
I am in the process of still learning what I have. It was converted to 5 lug, etc. Still figuring it all out.
1949 5 Window 3100
