8 members (2-Ton, MNSmith, mick53, TUTS 59, Cletus1950, Peggy M, klhansen, EchoBravoSierra),
101
Mod | | | Forums66 Topics128,173 Posts1,057,041 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | This almost feels like it belongs but it looks like there is something missing from the front of the switch. http://rides.webshots.com/photo/2662131180098611668HglQfR Does this switch look like the rest of the 1950 AD’s out there?? Denny Graham Sandwich, IL
Denny G Sandwich, IL
| | | | | Joined: Feb 2006 Posts: 1,867 Shop Shark | | Shop Shark Joined: Feb 2006 Posts: 1,867 | Looks just like mine in the 53, but Im not sure if its ever been replaced although it still has some pretty worn gm keys with it. Also has 2 pin holes in the face, at 12 and 2:00ish.
Jeff | | | | | Joined: Jan 2005 Posts: 1,602 Shop Shark | | Shop Shark Joined: Jan 2005 Posts: 1,602 | Mine has only one hole in it but I have a replacement that is keyed for the glovebox, doors and ignition that has two holes in it. I haven't put in the two hole version as I wonder if it should be the one hole or two hole version originally? | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | What I was wondering about guys is the fact that there is now bezel or trim ring like I've seen on the later trucks. Tims Suburban for instance. This one looks like it was an after thought. Denny Graham Sandwich, IL
| | | | | Joined: Nov 2000 Posts: 700 Shop Shark | | Shop Shark Joined: Nov 2000 Posts: 700 | Denny - mine has a bezel ring threaded on. I couldn't tell you if it was generic to the truck though.
Don My 1941 in the Stovebolt Gallery My Photo AlbumBut I tried, didn't I? ... At least I did that. RP McMurphy The past belongs to the future...but only the present can preserve it. Besides the noble art of getting things done, there is a nobler art of leaving things undone. | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Boy Don, you Johnny on the spot today, what, you run out of things to do in the garage??? I was gonna stick this link in that Tim posted. It shows his switch rill nice and purty. http://72.228.53.69//Photos/Reassembly/slides/13_54%20clockdash.html Denny Graham Sandwich, IL
| | | | | Joined: Jan 2005 Posts: 1,602 Shop Shark | | Shop Shark Joined: Jan 2005 Posts: 1,602 | | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | Part numbers for ignition parts. 1954/55 had a bezel ring (2.198 - locking dial) on the front of the dash. The 47-53 ignition switch was held to the dash from the rear with a mounting plate (2.192). All years used the same switch/cylinder (2.188). I think yours looks original for 1950 (47-53 - no bezel ring). Tim | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | I'se askin' this one, because out of the hundred or cockpits that I looked into this summer they all had been mutilated, opps, sorry, I mean "customized". Dern near impossible to find a stock Advanced Design truck round these parts at any of the shows that I went to. I only found one show that was in any way connected with VCCA and there wasn't one stock AD there. Thanks for the info guys. Well if that's the original switch, then I still think it reeks of Rube Goldberg who must have been the designer. Denny Graham Sandwich, IL
| | | | | Joined: Jan 2005 Posts: 1,602 Shop Shark | | Shop Shark Joined: Jan 2005 Posts: 1,602 | I don't see a bezel in the factory assembly manual for 47-54. | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | 1947-1954 Factory Assembly Manual
Section 12; Sheet 4.02
Lower left image: 3100-3600-3800-4000-5000-6000 VIEW B
1917129 MOUNTING NUT ASSY (that's the 54/55 bezel) | | | | | Joined: Nov 2000 Posts: 700 Shop Shark | | Shop Shark Joined: Nov 2000 Posts: 700 | Boy Don, you Johnny on the spot today, what, you run out of things to do in the garage??? Not hardly. Actually, I think my newly remanufactured 235 is going to have to be pulled and taken back for another reman-reman. The engine now has 400 miles on it since a complete reman but there is something about a mysterious clunk, clunk, clunk towards the forward end that I'm not real comfortable with. This noise seems to increase at idle as the engine heats up. I've done the rod to ear thing but can't pinpoint the location. It's just not right. It's a real bummer to get the truck to where I have it and now think about yanking the engine. Anyway, I'll take a photo of the ignition switch for you. This switch is actually rather a pain as the wiring is encapsulated in spiral wound metal flex conduit. I have no idea as to where the po may have come across it but I've found odder things during this rebuild. Don My 1941 in the Stovebolt Gallery My Photo AlbumBut I tried, didn't I? ... At least I did that. RP McMurphy The past belongs to the future...but only the present can preserve it. Besides the noble art of getting things done, there is a nobler art of leaving things undone. | | | | | Joined: May 2005 Posts: 334 'Bolter | | 'Bolter Joined: May 2005 Posts: 334 | I don't know about the 47 - 53, but Tim is correct on the 54's having a bezel ring - my 54 is original and it has one. Samantha | | | | | Joined: Feb 2006 Posts: 428 'Bolter | | 'Bolter Joined: Feb 2006 Posts: 428 | The pic looks like switch in my 52. I suspect that it is made that way so that the light next to the switch illuminates the switch when the dash lights are on. | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | It does do that Jimmie D! Thanks Sam, ya I'm sure by '54 they had fired Rube and an gotten a real designer in place. Hey Don, I thought that's the way the Bolt was supposed to sound??? Denny Graham Sandwich, IL
| | | | | Joined: Nov 2000 Posts: 700 Shop Shark | | Shop Shark Joined: Nov 2000 Posts: 700 | Since I don't want to hi-jack your thread I'll post the answer over in the Engine & Driveline shop as a new thread.
Don My 1941 in the Stovebolt Gallery My Photo AlbumBut I tried, didn't I? ... At least I did that. RP McMurphy The past belongs to the future...but only the present can preserve it. Besides the noble art of getting things done, there is a nobler art of leaving things undone. | | | | | Joined: Jan 2005 Posts: 1,602 Shop Shark | | Shop Shark Joined: Jan 2005 Posts: 1,602 | I see the ring in the manual. I don't have one on my 51 and I'm guessing it must be just for the 1954. Sorry I didn't see that page ealier. | | | | | Joined: Aug 2006 Posts: 108 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2006 Posts: 108 | Your switch looks just like mine (1951), and appears to be stock, the switch face looks sloppy with the gap between it and the dash hole, but this small circular space around the switch face is there to allow the light from the ignition switch light (behind) to illuminate the ignition switch face when the headlight/parking lights are turned on. Putting on a bezel would clean up the appearance but would render the light feature useless.
Best Regards Will
| | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Yep it sounds like that's the deal, just as JimmyD noted a couple of weeks ago. Make the hole to big for the switch so some light can leak out! Denny G
