| | | Forums66 Topics128,050 Posts1,055,673 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2002 Posts: 571 Shop Shark | | Shop Shark Joined: Dec 2002 Posts: 571 |  I think my 49 truck may have a 54 frame. I seem to remember someone saying the 54 had a bit higher kick up above the rear end. My bedwood sits on the frame at that point and the bed looks like it slopes downhill toward the cab. Did the shock mounts rivet or bolt in the 54 frames? (mine are bolted) I noticed a frame indentation where the 54 license plate should be on mine as well.  Thanks for the help in advance.  | | | | | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | Actually its the other way around. The kickup on the '54 is lower than '53 and earlier. The lower kickup allowed a lower bed floor and a deep bed.
1955 1st GMC Suburban | 1954 GMC 250 trailer puller project | 1954 GMC 250 Hydra-Matic | 1954 Chevy 3100 . 1947 Chevy COE | and more... It's true. I really don't do anything but browse the Internet looking for trouble... | | | | | Joined: Oct 2007 Posts: 52 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2007 Posts: 52 | | | | | | Joined: Oct 2001 Posts: 3,458 Extreme Gabster | | Extreme Gabster Joined: Oct 2001 Posts: 3,458 | Sub has it right. The shock mounts are riveted on my '50 frame. The '49 should have had lever action shocks originally.
You should have stepped spacer blocks on each bed crossmember to make it come out level.
Paint & Body Shop moderator A lone amateur built the Ark. A large group of professionals built the Titanic. | | | | | Joined: Dec 2002 Posts: 571 Shop Shark | | Shop Shark Joined: Dec 2002 Posts: 571 | Thanks for the help. It looks like the gap between the running board apron and the bottom of the bedside will be too big if I lift the front of the bed and/ or lower the rear of the bed. The fenders are bolted to the running board ends and will be out of whack too. I do not think the frame is bent. I put a long straight edge on the flat parts and seemed to be good.  | | |
