2 members (papas52, 2-Ton), 110 guests, and 2 robots.
Topics128,115
Posts1,056,292
Members48,439
#333498 11/05/2007 10:40 PM
Hello there,
I have a stock 54 Chevy 6400. I have been looking into adding an overdrive. I have noticed that a lot of people install 3 speed Brownies or Spicers to get an overdrive.
I'd like to go a different route. Does anyone have any personal experience with the Ranger 2 Speed AUX trans offered by High-Impact? They appear to be direct bolt-on units to a 235 and SM420. The only problem I forsee is that the shift tower on the SM420 will have to be relocated 7.5inches to the rear, which might put it beneath the bench seat in these vehicles.
Any insight would be appreciated,
Elias
From what I've heard, they're good aux transmissions and handle lots of torque. I don't have personal experience, but judging by the location of the shifter in the cab,, you 'd almost definately have to modify the shifter arm to curve out from under the seat, because I think you're right,, it's going to be under the front of it.
Jon
I have sceen one or two trans overdrives with a couple diferent versions, maybe with luck ranger might have one. I think it was a t6 or something like that, think he said they used them in vets. Maybe it was trimex, they had 5 and 6 speeds - they had about three different choices to move the shifter. Just a thought, the ranger sounds neat. How much do they run, do they have a web site? I dont need one now, but its interesting good luck.
You would be better off with an NV4500 tran's. . . 1st is granny 5th is OD bolt's right up to the 235 I-6. . . you'll only gain about 7.5-12.5 mph depending on how heavly over the truck is . . .
The seat could be an issue requiring a custom shifter.
The truck will get very doggy once it's engaged into over drive mode so be warned of that . . . In a 1965 ford F-700 i had a ran a 5.9L diesel 6spd with 3 speed auxy worked out well ,I had low driect and high. . . Truck would run 75mph loaded but even with the diesel it lugged down fast in the hill's. . .
Mike
1962 GMC K3000, GMC-379 V6.
I am thinking about putting a ranger overdrive in my 66 C30, not to go faster but rather to save gas and be able to split the gears. My truck is used for work and I need to keep the low geared rearend but its hard to afford to drive it much at 8 mpg. I am curious how much difference an overdrive would make in fuel economy. If I could pick up at least 2 or 3 mpg it would probably be worth it
Take a look at this I think this is the way I will be going with for my 56 6100
.http://www.jpmagazine.com/techarticles/drivetrain/154_0509_spicer_3053a_transmission/index.html
The difference between men and boys is the price of their toys.
Grant from Roy, Washington
1956 6100 Chevy Dump Truck in the Gallery
1964 GMC Drump Truck in the Gallery
user
http://s1301.photobucket.com/user/56Taskforce/slideshow/
user
Oh well don't know why the first one didn't work they are identical
user
oh Hell I never add OD's for fuel milage i do it for road speed tho you still gain some milage only about 2.5 MPG on average. . .
My B61T with the stock Mack tri plex ran 58mph@2250rpm 4MPG with Mikey's version of the triplex it run's 72mph@2,000rpm 6MPG <<< not bad for 1959. . .thats an extra 14mph & 2mpg with a truck that has 6.38 gear's,12.00-20 tires. . .I can still pull D9 cat's with it. . .Due to old tech brake i only run it about 67mph loaded that heavy. . .
Amazing what you can do by adding a turbo to high compression NON-Turbo diesel and altering the trans behind it. . .
I used the Mack single 5 spd from an army truck 5th gear is an OD put a 3 spd auxy behind it's still a 2 stick 15spd but i got dual OVER DRIVE's. . .
thats what I call teaching an old bull dog New trick's grin. . .
Mike
