| | | Forums66 Topics128,070 Posts1,055,896 Members48,428 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2007 Posts: 3 New Guy | | New Guy Joined: Oct 2007 Posts: 3 | I just purchased my first Big Bolt. Its a 56 Chevy 6500 in great condition. It runs and drives and needs little. Mainly some maintenance and tires. Any suggestion for a good inexpensive source for 8.25x20 tires. Are there any service manual available for these trucks. Below is the link to a picture of the 56. http://www.fototime.com/4EEA39D0F5C8D59/standard.jpgThanks ..... Bob
1956 Chevy 6500
| | | | | Joined: Feb 2007 Posts: 195 Shop Shark | | Shop Shark Joined: Feb 2007 Posts: 195 | I like it. Looks to be in very good condition. Cant help you on tires or service manual though.
Red meat is not bad for you.........Fuzzy green meat is bad for you!
"What happens in the garage stays in the garage!"
1958 Chevy Spartan 100 firetruck in the Gallery
| | | | | Joined: Apr 2005 Posts: 926 Shop Shark | | Shop Shark Joined: Apr 2005 Posts: 926 | Hi Bob; I've heard it mentioned that good "pre-owned" tires can sometimes be bought from school districts,as they have to replace the bus tires way before they're worn out. Also,at least around here,the tire shops always seem to have plenty of good used ones for repatively low prices. I guess for new tires,I'd probably look at Costco or Les Schwab. Speed
| | | | | Joined: Feb 2002 Posts: 2,893 Socket Breaker | | Socket Breaker Joined: Feb 2002 Posts: 2,893 | up here at the top, if you go to links, then parts, the vendors who sell parts, usually sell the reproduction shop manuals. The manuals cover all the different sizes of trucks for that year , from half ton to 2 ton or so, depending on the ton options for each year model. for instance, Jim Carter's has these for sale: http://www.oldchevytrucks.biz/55_66/full.asp?page=69You would probably need the '55 2nd series(which is your body style) and the '56 supplement. The accessory listing for 1956, has things about the doodads for that year model. -W | | | | | Joined: Jul 2004 Posts: 2,987 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 2,987 | Great looking truck!! Congratulations! | | | | | Joined: Dec 2002 Posts: 2,549 'Bolter | | 'Bolter Joined: Dec 2002 Posts: 2,549 | Too bad you're so far away. I've got the tires you need, out in my shop.. | | | | | Joined: Jan 2007 Posts: 63 New Guy | | New Guy Joined: Jan 2007 Posts: 63 | Congrads! She's a beauty. | | | | | Joined: Apr 2006 Posts: 453 Shop Shark | | Shop Shark Joined: Apr 2006 Posts: 453 | Nice truck...You can give these guys a try for tires. http://www.tuckertire.com/ | | | | | Joined: Oct 2007 Posts: 3 New Guy | | New Guy Joined: Oct 2007 Posts: 3 | Thanks for the suggestions. Tucker tire has some great prices. Will probably use them for the tires. Found a reproduction 55 2nd series manual and a new 56 supplement on ebay. I am ready to go. Next project is brakes. Got in it yesterday and had no brake pedal. No fluid in the master cyclinder. No visible leaks. Any suggestions,
Bob
1956 Chevy 6500
| | | | | Joined: Oct 2007 Posts: 3 New Guy | | New Guy Joined: Oct 2007 Posts: 3 | Spanky, what tires do you have and how much are you asking? Might be worth shipping them, Bob
1956 Chevy 6500
| | | | | Joined: Dec 2006 Posts: 720 'Bolter | | 'Bolter Joined: Dec 2006 Posts: 720 | Bob, the brakes are probably going to need to be gone through front to back. I started out just needing a master cylender and ended up replacing everything but my rear slaves and the shoes. You'll want to take it all apart and clean it up, odds are the inside of each wheel cylender is pitted with rust, as well as the lines themselves (the one across my rear axle was about as strong as a soda straw!). Just good to plan on redoing it all on something this old, and Napa stocks pretty much everything you'll need.
Do you have a brake booster under there as well? 1956 GMC 370 dump " 'Tater "1970 VW Volksrod "the Black Bomber" 2007 Chevy Avalanche 2020 Jeep Cherokee Trailhawk, 2005 Harley Davidson FLHTCUI I dig all cars, old and new, whether they were hammered out of American iron, German steel, or Japanese tin cans. Being unable to appreciate them all is missing out on a world of great things. But thats just MY opinion! :P
| | | | | Joined: May 2005 Posts: 323 Shop Shark | | Shop Shark Joined: May 2005 Posts: 323 | Does your truck have the 6 lug bolt pattern all around? If so you can find the 6 lug 22.5" budd wheels at big truck wrecking yards or tire shops swap over and run 22.5 radials which are readily avaiable and smoother to drive on. I've done that on 2 of my 6500 trucks. You don't notice any differences on the looks. | | |
