9 members (moparguy, Bill Hanlon, GRNHydra, Otto Skorzeny, mason86, klhansen, Gray_Ghost, mick53, Hawkman), 93 guests, and 2 robots.
Topics128,069
Posts1,055,886
Members48,428
#330328 10/30/2007 3:07 AM
I just purchased my first Big Bolt. Its a 56 Chevy 6500 in great condition. It runs and drives and needs little. Mainly some maintenance and tires. Any suggestion for a good inexpensive source for 8.25x20 tires. Are there any service manual available for these trucks. Below is the link to a picture of the 56.
http://www.fototime.com/4EEA39D0F5C8D59/standard.jpg
Thanks ..... Bob
1956 Chevy 6500
I like it. Looks to be in very good condition. Cant help you on tires or service manual though.
Red meat is not bad for you.........Fuzzy green meat is bad for you!
"What happens in the garage stays in the garage!"
1958 Chevy Spartan 100 firetruck in the Gallery
Cannonball #330439 10/30/2007 8:05 AM
Hi Bob;
I've heard it mentioned that good "pre-owned" tires can sometimes be bought from school districts,as they have to replace the bus tires way before they're worn out. Also,at least around here,the tire shops always seem to have plenty of good used ones for repatively low prices. I guess for new tires,I'd probably look at Costco or Les Schwab.
Speed
1954 GMC 350
1957 GMC 1/2 ton
1962 Chevy C-30
'98 Harley FLSTC
'66 Pontiac Catalina
'76 Chevy 1 ton Duallie
'84 Bronco II
'78 Dodge W-200
'81 Toyota 4X4 truck
speed 6351 #330762 10/31/2007 12:28 AM
Socket Breaker
Socket Breaker
up here at the top, if you go to links, then parts, the vendors who sell parts, usually sell the reproduction shop manuals.
The manuals cover all the different sizes of trucks for that year , from half ton to 2 ton or so, depending on the ton options for each year model.
for instance, Jim Carter's has these for sale:
http://www.oldchevytrucks.biz/55_66/full.asp?page=69
You would probably need the '55 2nd series(which is your body style) and the '56 supplement.
The accessory listing for 1956, has things about the doodads for that year model.
-W
Woogeroo #330836 10/31/2007 2:42 AM
Great looking truck!! Congratulations!
Rich
1947 Loadmaster
1947 Chev. Loadmaster
1959 Chev. Viking 40
Rich'sToys #330845 10/31/2007 2:52 AM
Too bad you're so far away. I've got the tires you need, out in my shop..
Spanky Hardy
More pictures on Photobucket
1950 GMC 250 1-Ton
Congrads! She's a beauty.
Nice truck...You can give these guys a try for tires.
http://www.tuckertire.com/
mummdogg #331383 11/01/2007 3:14 AM
Thanks for the suggestions. Tucker tire has some great prices. Will probably use them for the tires. Found a reproduction 55 2nd series manual and a new 56 supplement on ebay. I am ready to go. Next project is brakes. Got in it yesterday and had no brake pedal. No fluid in the master cyclinder. No visible leaks. Any suggestions,
Bob
1956 Chevy 6500
spanky #331384 11/01/2007 3:15 AM
Spanky, what tires do you have and how much are you asking? Might be worth shipping them,
Bob
1956 Chevy 6500
Bob, the brakes are probably going to need to be gone through front to back.
I started out just needing a master cylender and ended up replacing everything but my rear slaves and the shoes. You'll want to take it all apart and clean it up, odds are the inside of each wheel cylender is pitted with rust, as well as the lines themselves (the one across my rear axle was about as strong as a soda straw!). Just good to plan on redoing it all on something this old, and Napa stocks pretty much everything you'll need.
Do you have a brake booster under there as well?
1956 GMC 370 dump " 'Tater "
1970 VW Volksrod "the Black Bomber"
2007 Chevy Avalanche
2020 Jeep Cherokee Trailhawk,
2005 Harley Davidson FLHTCUI
I dig all cars, old and new, whether they were hammered out of American iron, German steel, or Japanese tin cans. Being unable to appreciate them all is missing out on a world of great things.
But thats just MY opinion!
:P
Does your truck have the 6 lug bolt pattern all around? If so you can find the 6 lug 22.5" budd wheels at big truck wrecking yards or tire shops swap over and run 22.5 radials which are readily avaiable and smoother to drive on. I've done that on 2 of my 6500 trucks. You don't notice any differences on the looks.
