5 members (stlcardinalsguy, WICruiser, Phak1, TUTS 59, 1 invisible), 98 guests, and 3 robots.
Topics128,167
Posts1,057,022
Members48,458
Apprentice
Apprentice
I have 3 bolts on the outside drivers door just under the wing vent,I tried to look inside the door to see what they are for but all I see is a steel plate.I want to omit these 3 bolts,can I bond the plate inside the door? or just remove the 3 bolts and maybe the plate all together? Most 65 chevys I see don't have these bolts or have removed them.
They are the bolt location for the factory mirrors. If you want to delete them, I would weld them shut. I've seen plastic and fiberglass patches crack out after a short while,
Scott
Scott Ward
2 1948 1.5-ton Loadmasters
1 1950 3100
1 1955.1 Chevy 6500
1 1954 Chevy 6500 2-Ton
1 1955 1st Series COE 5700
1 1963 K20 (454)
1 1964 C10 (350)
1 1951 1.5-ton Dump Truck
1953 and a 1956 Ford F800
Apprentice
Apprentice
Okay ,Thanks for the Quick Reply Scott
