| | | Forums66 Topics128,157 Posts1,056,877 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2006 Posts: 84 'Bolter | | 'Bolter Joined: Nov 2006 Posts: 84 | I am going out to visit the truck this weekend and plan on replacing the door glass (1948 GMC). What is the best way to go about this? It is about a 60 mile trip and would like any info you can give as far as tools, tips ect... so it is not a wasted trip.
Thanks. Trey | | | | | Joined: Nov 2005 Posts: 355 Member | | Member Joined: Nov 2005 Posts: 355 | I dont think your going to be able to do it like you want to. Its sometimes a bear to get the door parts off. You need to have about anything that kills along with you. Might be you should go take the doors off it, bring them back home were you can work on them with all your tools handy. Some thing on them just have to soak in P oil before you can move them. | | | | | Joined: May 2003 Posts: 1,271 Shop Shark | | Shop Shark Joined: May 2003 Posts: 1,271 | This may be helpful (I hope) ... it is a bit of a bear of a project ... but it wasn't all that bad for me: Click Here And Here
~~ Alan Horvath 1954 Chevy PickupSinging his praises in thePassing Lane | | | | | Joined: Mar 2004 Posts: 3,068 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 3,068 | There's going to be some clutch head screws that won't want to come loose. You'll need every possible size and type of locking pliers made, probably a hammer and chisel, some heat would be nice and a standard socket/wrench set with a variety of screw drivers. A fully charged cordless drill with a fresh set of bits to release the bolts that the other tools won't get too.
Use some penetrating oil on the mechanisms first and work them so they work easier because you'll have to move the regulator some to get it apart. Besides, it would be easier to free-up when it's still mounted to the door. Good luck, Scott | | | | | Joined: Nov 2006 Posts: 84 'Bolter | | 'Bolter Joined: Nov 2006 Posts: 84 | thanks for the info guys. Trey | | |
