Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
2 members (carbking, Shade Baby), 106 guests, and 3 robots.
Topics128,281
Posts1,058,471
Members48,490
I am going out to visit the truck this weekend and plan on replacing the door glass (1948 GMC). What is the best way to go about this? It is about a 60 mile trip and would like any info you can give as far as tools, tips ect... so it is not a wasted trip.
Thanks.
Trey
I
I Offline
I dont think your going to be able to do it like you want to. Its sometimes a bear to get the door parts off. You need to have about anything that kills along with you. Might be you should go take the doors off it, bring them back home were you can work on them with all your tools handy. Some thing on them just have to soak in P oil before you can move them.
Jeff
1947 Chevy 6400 2-ton
1953 3/4-ton
It was fun while it lasted
This may be helpful (I hope) ... it is a bit of a bear of a project ... but it wasn't all that bad for me:
Click Here
And Here
~~ Alan Horvath
1954 Chevy Pickup
Singing his praises in the
Passing Lane
There's going to be some clutch head screws that won't want to come loose. You'll need every possible size and type of locking pliers made, probably a hammer and chisel, some heat would be nice and a standard socket/wrench set with a variety of screw drivers. A fully charged cordless drill with a fresh set of bits to release the bolts that the other tools won't get too.
Use some penetrating oil on the mechanisms first and work them so they work easier because you'll have to move the regulator some to get it apart. Besides, it would be easier to free-up when it's still mounted to the door.
Good luck,
Scott
Scott Ward
2 1948 1.5-ton Loadmasters
1 1950 3100
1 1955.1 Chevy 6500
1 1954 Chevy 6500 2-Ton
1 1955 1st Series COE 5700
1 1963 K20 (454)
1 1964 C10 (350)
1 1951 1.5-ton Dump Truck
1953 and a 1956 Ford F800
thanks for the info guys.
Trey
