5 members (Hotrod Lincoln, Southerntruck, frogfarmer, 3B, Nick in Manitou), 141 guests, and 3 robots.
Topics128,089
Posts1,056,433
Members48,443
Yes, Yes, I know! This is supposed to be a site for trucks. However, I have been using it for the past couple of years for help with restoring my 57 Chevy 210 Sedan, faithfully equipped with the tried and true 235! Many thanks to the people that have helped me with this process. I am proud to say that the Chevy is finished.
Back to the subject at hand.. I am presently looking at purchasing another project vehicle.. a 50 Pontiac SilverStreak equipped with an in-line 8 and hydromatic 3-speed. The engine runs great, and I would like to keep it, but I HATE that tranny! Does anyone know if the 700R4 or 200-4R will bolt up to that engine? I know I'll have to get a new rear-end with open driveshaft, but I need to know if either of these trannys would work... or if an adapter plate exists. Any information on this would help greatly!
Thanks for all of your help.. Even if it is for a Car!
'57 Chevy 210 (235)
'54 Chevy 3800
'49 Pontiac Streamliner (239)
'46 Chevy 3/4-Ton (216) (Sold)
'46 Chevy 1 1/2-Ton (Sold)
'50 Chevy Loadmaster Semi (Sold)
'68 Chevy Stepside (Sold)
Try the POCI board for help with that Pontiac. My bet is that they will not bolt up. The Pontiac never used any thing but a 350 or 400 Turbo and the bolt patterns were different from the Chevrolet. Some sort of a adapter will have to be used for anything other than whats in it. Are you sure the side mounts are not part of the transmission? Joe
If it works, why mess with it???? Those were good trannies in their day. Just have to get used to the R being where Low usually is now, and maybe no park position on that early of one. That's part of the "charm" of owning classic stuff, it's different! Don't be a "Hacker". :p
G.L. Grumpy's
Old Iron Ranch
Huntington, IN 46750
MM R tractor, Speedex
and Power King tractors
If it is a Hydramatic, it is most likely a 4 speed. When you shift the gearshift lever to reverse and shut the engine off, that transmission will lock into park and the car will not move..
If it goes forward smoothly and backs up, what is to hate ? They were used all through the '50's and known as a durable transmission..I agree with GL..
Bill M
53 GMC Hydra-Matic
Home Page
http://home.comcast.net/~bd97/index.html
When you argue with a fool, two fools are arguing..
Try the Inliners International web site.
They've got great technical info on most american (and some foreign) inline engines. I believe the website is www.inliners.org.
Bump....
(In case Oly missed all the excitement!)
grin
Then you will know the truth, and the truth will set you free.
- Jesus -
