8 members (pauld, lumbersawyer, Gdads51, frogfarmer, J Lucas, carbking, Charles in CA, 1 invisible), 99 guests, and 7 robots.
Topics128,264
Posts1,058,358
Members48,485
#327344 02/07/2006 12:43 AM
My doors are a mess! I have been buying what parts I can where I can find them. I even considered shaving and adding poppers. NAW, that wouldnt be right. I would like to know if there is a detailed paper out there describing how to rebuild these. It has the kewl upswing handles and vent windows. So I dont want to change out to a 50 , etc.. I realize my truck is a "little different", but Im trying hard to keep as many lines original as I can. Thanks.
http://www.geocities.com/pickinjim1/Jims51truck.html
#327345 02/07/2006 5:19 PM
Apprentice
Apprentice
I have completely stripped/gutted the doors on mine, but that isn't saying too much considering the condition the truck was in to begin with.
Anyway, I almost have the second door blocked out enough to put a final coat of primer on before setting aside for storage.
What specifically do you need? I hope to put together a step by step when the time comes, but may be able to help out with some pictures etc until then. grin
#327346 02/07/2006 11:50 PM
Gosh, just a hand sketch or digi pics of the window track setup and the door latching would be sooooooooo helpful! Thanx!
jims 51
#327347 02/08/2006 2:45 AM
Just tear one side apart at a time and use the other one as a reference. Tear one down and lube up everything that moves or is supposed to move and replace anything that is made of rubber. Make sure you have a tap and die set and some new screws to replace them darn clutch heads,
Scott
Scott Ward
2 1948 1.5-ton Loadmasters
1 1950 3100
1 1955.1 Chevy 6500
1 1954 Chevy 6500 2-Ton
1 1955 1st Series COE 5700
1 1963 K20 (454)
1 1964 C10 (350)
1 1951 1.5-ton Dump Truck
1953 and a 1956 Ford F800
#327348 02/08/2006 4:54 AM
I
I Offline
Oh Scott, just say the clutch head is my friend. We have stripped out six and a half pair of doors so far in getting a perfect pair for the 47. Thats a lot of clutching man. its amazing how many parts are in just one door, and how a fairly "good" door looks like crap after you strip it.
Jim, I have several factory manuals and books showing differnt exploded views. I'll look and see if any of them have your style door in them. I'll post something this weekend if I find it.
Jeff
1947 Chevy 6400 2-ton
1953 3/4-ton
It was fun while it lasted
#327349 02/08/2006 5:09 AM
"Clutch head is my friend" "Clutch head is my friend". Sorry Jeff, it ain't workin', I still hate them, LOL
Scott
Scott Ward
1 1950 3100
1 1955.1 Chevy 6500
1 1963 K20 (454)
1 1964 C10 (350)
#327350 02/09/2006 3:19 AM
Iowa, that would be super dooper! Thanks.
#327351 02/09/2006 4:24 AM
I
I Offline
Jim, I sent you a PDF file with the door on it. Hope it wasnt to big for you to receive. If you cant open it and have trouble I'll try something else.
Jeff
1953 3/4-ton
#327352 02/10/2006 3:34 AM
Iowa, try somethun' else. LOL Couldnt open that.
#327353 02/10/2006 4:43 PM
Apprentice
Apprentice
I wouldn't mind seeing a copy of that pdf file if you don't mind sending it to me.
Would you like for me to try to get some pictures of my doors and parts?
#327354 02/10/2006 6:19 PM
I
I Offline
Ok it appears that its to big to send out the way I did it so I'll try and make it smaller and resend it.
Jeff
1953 3/4-ton
#327355 02/11/2006 4:55 AM
I
I Offline
Bret, cant send it to you as your email contact dont allow an attachment. You will have to email me and i'll return the file to you in a reply.
Jeff
1953 3/4-ton
#327356 02/13/2006 3:07 PM
Apprentice
Apprentice
Jeff, email sent-thanks!
I have taken some pictures of my pass sid edoor, but I am having trouple uploading them to my website. I'll post an update when I have them up.
#327357 02/18/2006 4:17 PM
Apprentice
Apprentice
I got soem pictures up. Let me know if you need more!
http://mypeoplepc.com/members/thecopseys/1951chevytruck/
