| | | Forums66 Topics128,264 Posts1,058,357 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2004 Posts: 73 Member | | Member Joined: Jun 2004 Posts: 73 | My doors are a mess! I have been buying what parts I can where I can find them. I even considered shaving and adding poppers. NAW, that wouldnt be right. I would like to know if there is a detailed paper out there describing how to rebuild these. It has the kewl upswing handles and vent windows. So I dont want to change out to a 50 , etc.. I realize my truck is a "little different", but Im trying hard to keep as many lines original as I can. Thanks. http://www.geocities.com/pickinjim1/Jims51truck.html | | | | | Joined: Nov 2005 Posts: 23 Apprentice | | Apprentice Joined: Nov 2005 Posts: 23 | I have completely stripped/gutted the doors on mine, but that isn't saying too much considering the condition the truck was in to begin with. Anyway, I almost have the second door blocked out enough to put a final coat of primer on before setting aside for storage. What specifically do you need? I hope to put together a step by step when the time comes, but may be able to help out with some pictures etc until then.  | | | | | Joined: Jun 2004 Posts: 73 Member | | Member Joined: Jun 2004 Posts: 73 | Gosh, just a hand sketch or digi pics of the window track setup and the door latching would be sooooooooo helpful! Thanx! jims 51 | | | | | Joined: Mar 2004 Posts: 3,068 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 3,068 | Just tear one side apart at a time and use the other one as a reference. Tear one down and lube up everything that moves or is supposed to move and replace anything that is made of rubber. Make sure you have a tap and die set and some new screws to replace them darn clutch heads, Scott | | | | | Joined: Nov 2005 Posts: 355 Member | | Member Joined: Nov 2005 Posts: 355 | Oh Scott, just say the clutch head is my friend. We have stripped out six and a half pair of doors so far in getting a perfect pair for the 47. Thats a lot of clutching man. its amazing how many parts are in just one door, and how a fairly "good" door looks like crap after you strip it.
Jim, I have several factory manuals and books showing differnt exploded views. I'll look and see if any of them have your style door in them. I'll post something this weekend if I find it. | | | | | Joined: Mar 2004 Posts: 3,068 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 3,068 | "Clutch head is my friend" "Clutch head is my friend". Sorry Jeff, it ain't workin', I still hate them, LOL Scott | | | | | Joined: Jun 2004 Posts: 73 Member | | Member Joined: Jun 2004 Posts: 73 | Iowa, that would be super dooper! Thanks. | | | | | Joined: Nov 2005 Posts: 355 Member | | Member Joined: Nov 2005 Posts: 355 | Jim, I sent you a PDF file with the door on it. Hope it wasnt to big for you to receive. If you cant open it and have trouble I'll try something else. | | | | | Joined: Jun 2004 Posts: 73 Member | | Member Joined: Jun 2004 Posts: 73 | Iowa, try somethun' else. LOL Couldnt open that. | | | | | Joined: Nov 2005 Posts: 23 Apprentice | | Apprentice Joined: Nov 2005 Posts: 23 | I wouldn't mind seeing a copy of that pdf file if you don't mind sending it to me.
Would you like for me to try to get some pictures of my doors and parts? | | | | | Joined: Nov 2005 Posts: 355 Member | | Member Joined: Nov 2005 Posts: 355 | Ok it appears that its to big to send out the way I did it so I'll try and make it smaller and resend it. | | | | | Joined: Nov 2005 Posts: 355 Member | | Member Joined: Nov 2005 Posts: 355 | Bret, cant send it to you as your email contact dont allow an attachment. You will have to email me and i'll return the file to you in a reply. | | | | | Joined: Nov 2005 Posts: 23 Apprentice | | Apprentice Joined: Nov 2005 Posts: 23 | Jeff, email sent-thanks!
I have taken some pictures of my pass sid edoor, but I am having trouple uploading them to my website. I'll post an update when I have them up. | | | | | Joined: Nov 2005 Posts: 23 Apprentice | | Apprentice Joined: Nov 2005 Posts: 23 | | | |
