| | | Forums66 Topics128,089 Posts1,056,144 Members48,436 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2005 Posts: 170 Member | | Member Joined: Mar 2005 Posts: 170 | What type of antenna would have been used on the '39-'46 type cab? Where should it be located? Is there a suitable reproduction available? I looked at my '40 and the left side of the cowl is just about vertical. It seems like there would be enough room to put one there without interfering with the door or the gullwing hood.
Ideas?
Thanks, Steve | | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | If you don't get an answer here, try the VCCA site. You will probably get very specific instructions on the site. | | | | | Joined: Jan 2000 Posts: 2,074 'Bolter | | 'Bolter Joined: Jan 2000 Posts: 2,074 | My 46 came with the side mount type antenna on the driver's side cowl. This should be as original as the ad-on radio mounts to the left of the steering column. In the Gallery go to Jim Merritt's 46.
Jim Carter's or Chevs of the 40s should stock this antenna or maybe your local auto parts? | | | | | Joined: Mar 2005 Posts: 170 Member | | Member Joined: Mar 2005 Posts: 170 | Thanks Jim, thats what I wanted to see. I'm looking at a period, aftermarket radio to mount to the left of the steering column. That antenna looks just right. Steve | | | | | Joined: Feb 2005 Posts: 338 Shop Shark | | Shop Shark Joined: Feb 2005 Posts: 338 | I thought I read somewhere that there was an under running board antenna option for these trucks. Anyone ever heard of or seen anything like that? I'm not one to shave door handles and such, but I just don't like the look of an antenna grafted on to the side of the cab.
Bill Schickling | | | | | Joined: Mar 2001 Posts: 629 'Bolter | | 'Bolter Joined: Mar 2001 Posts: 629 | Why not just mount one under the dash?
Tim Sheridan 1947 First Series Chevy 1/2-Ton"Liberty Series" - "Art Deco" - Whatever you'd like to call it. In the Gallery | | | | | Joined: Mar 2005 Posts: 170 Member | | Member Joined: Mar 2005 Posts: 170 | I'm planning on using an original, period radio. There is no need to hide the antenna. It seems to me a hidden antenna would be out of place. If I was using a modern radio in the glove box, I could see hiding the antenna. The dual side mount type antenna looks good to me. I see on Alan Horvath's site he mentions the new ones from Chevy Duty have plastic mounts, not metal. Anyone know who has the metal mount types? Thanks, Steve | | |
