4 members (Hotrod Lincoln, Otto Skorzeny, Bill Hanlon, 1 invisible), 70 guests, and 1 robot.
Topics128,090
Posts1,056,026
Members48,432
#326519 01/27/2006 1:55 AM
What type of antenna would have been used on the '39-'46 type cab? Where should it be located? Is there a suitable reproduction available? I looked at my '40 and the left side of the cowl is just about vertical. It seems like there would be enough room to put one there without interfering with the door or the gullwing hood.
Ideas?
Steve
See my 1940 Canadian GMC:
http://community.webshots.com/user/ndnchf
#326520 01/27/2006 1:09 PM
If you don't get an answer here, try the VCCA site. You will probably get very specific instructions on the site.
1951 1 Ton Completed
#326521 01/27/2006 4:22 PM
My 46 came with the side mount type antenna on the driver's side cowl. This should be as original as the ad-on radio mounts to the left of the steering column. In the Gallery go to Jim Merritt's 46.
Jim Carter's or Chevs of the 40s should stock this antenna or maybe your local auto parts?
1946 1/2-Ton Chevy
#326522 01/27/2006 9:44 PM
Thanks Jim, thats what I wanted to see. I'm looking at a period, aftermarket radio to mount to the left of the steering column. That antenna looks just right.
Steve
#326523 01/29/2006 2:16 PM
I thought I read somewhere that there was an under running board antenna option for these trucks. Anyone ever heard of or seen anything like that? I'm not one to shave door handles and such, but I just don't like the look of an antenna grafted on to the side of the cab.
Bill Schickling
Bill Schickling
1940 1/2 ton, 1940 3/4 ton
My web page
#326524 01/29/2006 5:22 PM
Why not just mount one under the dash?
Tim Sheridan
1947 First Series Chevy 1/2-Ton
"Liberty Series" - "Art Deco" - Whatever you'd like to call it.
#326525 01/29/2006 6:56 PM
I'm planning on using an original, period radio. There is no need to hide the antenna. It seems to me a hidden antenna would be out of place. If I was using a modern radio in the glove box, I could see hiding the antenna. The dual side mount type antenna looks good to me. I see on Alan Horvath's site he mentions the new ones from Chevy Duty have plastic mounts, not metal. Anyone know who has the metal mount types?
Steve
Moderated by  truckernix
