3 members (Materman, blanch53, 1 invisible), 125 guests, and 2 robots.
Topics128,072
Posts1,055,906
Members48,429
#32175 03/23/2004 1:37 AM
ok the engine has a fresh rebuild with an offenhauser dual 1 barrel carter setup, I am about to have the carbs checked out by our local carb guy, we can get the car running, but it seems to want to idle at about 3k rpms, and it will only start and stay running if I choke it, any help, anyone?
#32176 03/23/2004 1:49 AM
it sounds like the idle circuits are closed, or a big vacuum leak, or both. good luck.
our garage is a non-profit organization
#32177 03/23/2004 1:52 AM
idle circuits? what about the heat riser, I havent put on the heat riser spring?
#32178 03/23/2004 7:51 PM
The hear riser doesn't directly affect the idle, except when the engine is cold. All it does is warm the intake manifold with exhaust. Without the spring, the valve stays open. When the engine is cold, the spring closes the valve allowing hot exhaust to go to the intake.
Fred
52 3600
69 C-10
#32179 03/23/2004 10:43 PM
May not help, but my 216had a similar problem. Wouldn't idle less than 1500-2000 RPM, choke on. I checked the plugs and then the points. Gap was WAY off. Once fixed, it idles great when warm.
#32180 03/24/2004 12:03 AM
2 Offline
Had the same problem. Found that the intake manifold was sucking air from the bottom of the gasket. The fix was to grind the manifold. Found that the Fenton hedders were holding the intake at a slight angle and the intake would not fit the head flush. Grinding took place on the bottom of the intake for clearence between it and the headders. Intake sets flush to head and vacuum leak went away.
#32181 03/24/2004 12:38 AM
Thats my problem I think, I had the intake/exhaust manifold surfaced at napa, but I think the little rings that go inbetween the intake and head were too thick, I just picked up a new gasket and am going to hopefully get it all back together tomorrow.
Thanks for all the help everyone, I will update on the situation in a day or 2
