| | | Forums66 Topics128,111 Posts1,056,244 Members48,437 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#31083 05/28/2005 9:42 PM | | Anonymous Unregistered | | Anonymous Unregistered | Okay I like the look of a lowered truck. I know that many of you have removed a few leaf springs from the packs in order to get a lower stance. I am considereing doing this on my 53. Is it safe? This truck isn't going to be hauling any/many loads so I don't really care that way. Will I get way less travel and bottom out? How many can I remove? How many did you remove? How hard is it to do? Thank you very much!! | | |
#31084 05/29/2005 2:06 AM | Joined: Feb 2001 Posts: 4,095 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 4,095 | i removed 2 out of mine years ago and it worked fine, its been so long i have trouble remebering but i think i read every other one starting from the bottom. i am sure you will get other responses. look in the search something should come up. RON
Ron, The Computer Greek I love therefore I am.1954 3100 Chevy truckIn the Gallery 2017 Buick Encore See more pix1960 MGA Roadster Sold 7/18/2017
#31085 05/29/2005 4:36 AM | | Anonymous Unregistered | | Anonymous Unregistered | thanks Ron, about how much did it lower it? | | |
#31086 05/29/2005 2:26 PM | Joined: Feb 2001 Posts: 4,095 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 4,095 | its been so long but i think about 2" a lot depends on how fatigued your springs already are. you can make lowering springs from square tubing, the same used for boxed steel frames. there usually a minium charge which is high but if you explain what you are doing they may waive it, go in off peak. this sq. tubing comes different dimensions. 1x2. 2x2, 2x3 and so on, just decide how low you want to go. longer u bolts will be needed. ron
#31087 05/29/2005 4:35 PM | Joined: Feb 2000 Posts: 5,216 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 5,216 | I removed 3 from the front of my truck. I have had no problems, but I started with a new spring pack. I was just after a softer ride and didn't pay any attention to how much it lowered it. It won't be as much as you think, since each leaf is only 1/4" thick. It will drop more than that depending on how weak each leaf is. Start with the shortest ones. The more you take out, the softer the ride will be, BUT, take to many out and you could cause problems. The springs will act springier with less support under them, and under hard cornering or stopping you could get out of control very easy. You will also, need a stiffer shock to control some of bounce you added!
If you really want to lower it, go with a mono-leaf spring made for what you want. If you are after a better ride and a tad lower, pull out a few leafs.
Its a easy job once you have the spring out of the truck. Just one bolt in the center holds the pack together. Use a large C-clamp to hold the springs and remove the center bolt. Most of them will need broke off or cut off! Then loosen the clamp and let the pack loose. Now would be a good time to clean and inspect the rest of the group. A good local trailer shop or spring shop will have new center bolts. I used a Allen head bolt in mine. Just make sure the bolt head fits the locater hole in the axle. Joe | | |
#31088 05/29/2005 5:23 PM | Joined: Dec 2003 Posts: 1,554 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 1,554 | I removed 3 from my 55 2nd series rear.Has worked out fine.Lowered it about 4 in.I am however at a later date going to install new rear leaf setup and put the rearend on top of the springs.I have the kit,just have not found the time to get it done.AS far as the job is concerned it is an easy fix to remove some leafs.I would definitly get new thru bolts for the springs.Mine originally had 7 leafs. | | |
#31089 05/29/2005 8:53 PM | | Anonymous Unregistered | | Anonymous Unregistered | Thanks for all the replies guys! I have already put the rear diff on top of the leaves and it has made a big difference. My front leaf packs have 8 leaves and my rear one have 9. I have low profile radial tires of the original rims so I guess it has a pretty good stance right now. I was just debating wheather it was worth it to remove a few springs. Thanks again. | | |
#31090 05/30/2005 8:22 PM | Joined: Dec 2003 Posts: 2,953 'Bolter | | 'Bolter Joined: Dec 2003 Posts: 2,953 | Took mine to the local spring shop. They have the hoists, the axle supports and the hydraulic clamps to hold the spring while dis-assembling it. And they bent up the leaf clamps very quickly with a hydraulic tool. Didn't charge a lot of money and in my opinion I would not have wanted to do it myself. | | |
#31091 06/01/2005 3:44 AM | Joined: Dec 2004 Posts: 20 New Guy | | New Guy Joined: Dec 2004 Posts: 20 | From the posts above, it seems like it's safe to take three springs out of the pack, strting with the shorter ones on the bottom. I have a '51 3800 and the one ton springs are wider (and I think thicker) than those in the half-ton. Anyone out there taken springs from a one ton? If so, how many and how much did it improve the ride? Thanks | | |
