9 members (Southerntruck, MRMEROTH11, Oswald, moparguy, Hanks custodian, Jon G, Gray_Ghost, Peggy M, fonz8261), 107 guests, and 0 robots.
Topics128,068
Posts1,055,880
Members48,428
#29993 04/08/2005 7:02 PM
i have a pacer IFS and have ordered lowered springs for it. is it very hard to change them and how dangersous it it. i plan in leaving the shoks in place until i release the tension on the springs. any comments will be apreciated. ron
Ron, The Computer Greek
I love therefore I am.
1954 3100 Chevy truck
2017 Buick Encore
See more pix
#29994 04/09/2005 2:27 AM
They make a spring compressor that goes inside the spring where the shock is and pulls it up from the bottom. You compress the spring, drop the lower conrol arm out of the way and slowly release the spring without fear of it shooting out at you.
Be safe,
Scott
Scott Ward
2 1948 1.5-ton Loadmasters
1 1950 3100
1 1955.1 Chevy 6500
1 1954 Chevy 6500 2-Ton
1 1955 1st Series COE 5700
1 1963 K20 (454)
1 1964 C10 (350)
1 1951 1.5-ton Dump Truck
1953 and a 1956 Ford F800
#29995 04/09/2005 3:21 AM
You can probably rent them for cheap at an auto parts store.You can up here,in some places.MUCH SAFER and easier!
65 C10 292/700R4 long fleet...Gettin closer by the day.
#29996 04/09/2005 1:03 PM
thnaks your comments reminded me that auto zone loans those tools i will have to check into that, it was hearsay. thanks again, ron
2017 Buick Encore
See more pix
#29997 04/09/2005 1:25 PM
It's not worth the risk... use the spring compressor. It is free to borrow one from Autozone. They do, however, require a deposit which is refunded once the compressor is returned.
