1 members (delky), 65 guests, and 2 robots.
Topics128,049
Posts1,055,740
#29181 04/28/2004 7:08 PM
Junior Member
Junior Member
Hello all, My 66 c20 has a very irritating noise coming from the speedo. It works but the noise is making me want to disconnect it. Im pretty sure it's in the speedometer, but I guess it could be a bad cable. Is there any way to check which it might be? Also, if it is in the gauge, how hard is it to pull the speedometer and check it out.
Thanks for any assistance you can offer.
#29182 04/29/2004 3:43 AM
My '64 had the same problem. I unhooked the cable from the back of the head and pulled out the inner cable. I lubed it with a synthetic paste type lube as I pushed it back into the sleeve. Use a synthetic paste so it doesn't pump the lube up to the speedo head and so it won't thicken up in cold weather.It has been quiet for years now,
Scott
Scott Ward
2 1948 1.5-ton Loadmasters
1 1950 3100
1 1955.1 Chevy 6500
1 1954 Chevy 6500 2-Ton
1 1955 1st Series COE 5700
1 1963 K20 (454)
1 1964 C10 (350)
1 1951 1.5-ton Dump Truck
1953 and a 1956 Ford F800
#29183 04/29/2004 4:47 PM
Yep, same thing on my '65 C20. You'll probably just have to lube up that speedo cable. I was able to reach my hand behind the cluster and unscrew it, didn't have to pull the whole cluster out. If you do have to pull it, it's pretty dern easy and straightforward. Just poke your head under the dash and stare for a minute. If you've got gauges, I think it's best to separate the oil/fuel from back of cluster (held on with small sheet screws) before pulling it out. That is if your oil gauge is still hooked up with the original hard line. Good Luck.
Tradin' up dimes for nickels...
My \'65 Chevy C-20
#29184 04/29/2004 7:57 PM
Junior Member
Junior Member
Do you guys mean to pull the cable out from it's
sheathing and just lube up the inner part?
#29185 04/29/2004 11:11 PM
Yep,
Scott
Scott Ward
1 1950 3100
1 1955.1 Chevy 6500
1 1963 K20 (454)
1 1964 C10 (350)
#29186 04/30/2004 2:45 AM
Junior Member
Junior Member
Here's my 2 cents. Unhook it from the speedometer and drive it down the road. If the noice still happens, it's in the cable. If it stops it's in the gauge. Not high tech... but it's a plan that's worked for me
Ryan
#29187 04/30/2004 2:53 PM
Good idea to check with speedo disconnected. Mine was making quite a racket and lubing the cable did nothing. All the howling was the speedo - sprayed some WD-40 into the speedo opening (where the cable goes) and everything got nice and quiet.
I don't think my WD-40 fix is the most appropriate way to lube a speedo, but I have a spare I'm reworking and this was a quick fix. About 200 miles ago and still working fine though.
