5 members (Bisbee, Otto Skorzeny, Bill Hanlon, 54farmtruck, latroca52), 128 guests, and 4 robots.
Topics128,148
Posts1,056,813
Members48,454
#27904 06/25/2004 6:02 PM
Since I'm gonna be replacing the rear springs in my 64 C10 Ratt Truk
[img]http://www.chevyasylum.com/64c10/64c10_270r8.jpg[/img]
today, I thought I'd ask if anyone had any shortcuts or "easy ways" to do this. I was gonna remove the shocks (they're gonna be replaced, too) and jack the truck up by the frame, allowing the rear axle to drop down and (hopefully) pull the springs out. Just a thought...can I do this with the track rod still connected or does it have to be disconnected, too?
I've done this numerous times on G-body cars, but never on this model truck...so I'd appreciate anyone's experience or insight.
#27905 06/26/2004 1:53 AM
Z
Z Offline
its real easy.unbolt the bottom of the spring,jack up the truck til the springs loose,then unbolt the top.don't forget the jackstands.you will want to spray the threads with pb blaster a day earlier to loosen up the rust.
#27906 06/26/2004 3:36 AM
My '64 had a hold down bracket at the top and bottom of each spring. A couple were fairly rusty so I had to replace them. They are the only thing keeping the spring located to the trailing arm so make sure they are good before you disassemble. Other that that, it's a piece of cake,
Scott
Scott Ward
2 1948 1.5-ton Loadmasters
1 1950 3100
1 1955.1 Chevy 6500
1 1954 Chevy 6500 2-Ton
1 1955 1st Series COE 5700
1 1963 K20 (454)
1 1964 C10 (350)
1 1951 1.5-ton Dump Truck
1953 and a 1956 Ford F800
