1 members (Samantha),
45
Mod | | | Forums66 Topics128,179 Posts1,057,159 Members48,465 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2002 Posts: 12 Member | | Member Joined: Sep 2002 Posts: 12 | hi does any one know if you can take factory chevy passenger car 5 lug bolt front drums off 1950 to? and put them on a 56 chevy truck factory 6 bolt spindles swap 5 bolt drums for the original 6 bolt drums thanks | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | I'm not positive about what year starts and stops it but I did put the FRONT 5 lug drums off a 55-57 chevy car on my 1950 chev pickup. Just pull you old ones off and slide the others on...bearings and all. I couldn't do anything with the rear but I did find a set of 6 lug chrome wheels that set it off with the wide tires! I'm sure some one else will be along shortly that can answer your question completely and with out any doubt. Its only been 35 years since I did that particular one!  | | | | | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | yes Mitch, works fine - you can use the drums and hubs from the early car on the TaskForce truck spindles to get the 5 bolt - the early 5 bolt car rims also have the clips for the correct hub caps [6 clips for the earlier car, rather than the 3 on the TF truck 6 pin wheels] - bearings and brakes are the same too Bill | | | | | Joined: Sep 2002 Posts: 12 Member | | Member Joined: Sep 2002 Posts: 12 | thanks alot for your help | | |
