8 members (Donf, Gdads51, 55shaker, FAST55, Ponchogl, Wickedbass, Cosmo, Hanks custodian),
66
Mod | | | Forums66 Topics128,065 Posts1,055,868 Members48,428 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#27700 04/29/2003 11:11 PM | Joined: Jun 2002 Posts: 29 Junior Member | | Junior Member Joined: Jun 2002 Posts: 29 | My speedometer never worked, after I was done rebuilding my 58'1/2 ton the speedometer just screeched and bounced around wildly so I took the speedometer out. The ODOMETER worked fine. Because of a bad syncro in the original transmission I found a replacement from a 59. After the switch my odometer never worked. The cable hooks up the same. I even switched the speedometer gear on the side of the transmission. They looked identical but it didn't help. I assume the gear on the mainshaft of the transmission is out. any other ideas? should I rebuild the original transmission with the bad synchro or the working transmission which doesn,t turn my odometer(speedo cable)? | | |
#27701 04/30/2003 12:44 AM | Joined: May 2001 Posts: 1,904 'Bolter | | 'Bolter Joined: May 2001 Posts: 1,904 | The screeching and bouncing of the speedometer dial might be a bad cable. The turning part is really a tightly wound spring. It sticks a bit and then catches up. It happened to me on another truck. Can you take out the odometer to see if the drive gear or something else is stripped? 1948 3/4-Ton 5-Window Flatbed Chevrolet 34 Years. Now with a '61 261, 848 head, Rochester Monojet carb, SM420 4-speed, 4.10 rear, dual reservoir MC, Bendix up front, 235/85R16 tires, 12-volt w/alternator, electric wipers and a modern radio in the glove box.
#27702 04/30/2003 2:18 AM | Joined: Jul 2002 Posts: 385 'Bolter | | 'Bolter Joined: Jul 2002 Posts: 385 | Don't bother pulling the speedo apart; you should be able to find the correct speedo cable at NAPA for about $20 and I will be greatly surprised if there's anything else wrong. What you describe is "classic" broken/kinked cable. | | |
#27703 04/30/2003 6:34 PM | Joined: Jun 2002 Posts: 29 Junior Member | | Junior Member Joined: Jun 2002 Posts: 29 | The speedometer in the dash is long gone, when I took it out the screeching stopped. The odometer works on the same cable and was working just fine with no noise until I switched transmissions. Since I tried switching the external speedometer gear on the trani I assume it is the mainshaft gear? simple or hard to replace? | | |
