2 members (Hotrod Lincoln, greenie-reddy), 96 guests, and 2 robots.
Topics128,049
Posts1,055,741
#27700 04/29/2003 11:11 PM
Junior Member
Junior Member
My speedometer never worked, after I was done rebuilding my 58'1/2 ton the speedometer just screeched and bounced around wildly so I took the speedometer out. The ODOMETER worked fine. Because of a bad syncro in the original transmission I found a replacement from a 59. After the switch my odometer never worked. The cable hooks up the same. I even switched the speedometer gear on the side of the transmission. They looked identical but it didn't help. I assume the gear on the mainshaft of the transmission is out. any other ideas? should I rebuild the original transmission with the bad synchro or the working transmission which doesn,t turn my odometer(speedo cable)?
#27701 04/30/2003 12:44 AM
The screeching and bouncing of the speedometer dial might be a bad cable. The turning part is really a tightly wound spring. It sticks a bit and then catches up. It happened to me on another truck. Can you take out the odometer to see if the drive gear or something else is stripped?
#27702 04/30/2003 2:18 AM
Don't bother pulling the speedo apart; you should be able to find the correct speedo cable at NAPA for about $20 and I will be greatly surprised if there's anything else wrong. What you describe is "classic" broken/kinked cable.
1955 First Series GMC 250 1-Ton Panel
Mr. Hedgehog - Follow the build
If you can't laugh at yourself, I'll laugh at you.
#27703 04/30/2003 6:34 PM
Junior Member
Junior Member
The speedometer in the dash is long gone, when I took it out the screeching stopped. The odometer works on the same cable and was working just fine with no noise until I switched transmissions. Since I tried switching the external speedometer gear on the trani I assume it is the mainshaft gear? simple or hard to replace?
