1 members (1 invisible),
105
Mod | | | Forums66 Topics128,024 Posts1,055,395 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#27596 05/01/2004 9:55 PM | Joined: Jan 2004 Posts: 158 Member | | Member Joined: Jan 2004 Posts: 158 | Hi all, I have a 77 305 SBC that I rebuilt, but I dont know what the settings are for the vavles, do I use hot settings, or cold? Also what are they, or where can I find them?? Thanks guys,
- Shane
- Shane (ChevyToughRebel) 2 Trucks; -1955 3/4 Ton Chevy -1979 3/4 Ton Custom Deluxe 20 4x4 1955 Second Series 3600 GED = Git Er Done
#27597 05/02/2004 2:27 AM | Joined: Mar 2004 Posts: 3,068 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 3,068 | Are you running solid lifters? | | |
#27598 05/02/2004 8:04 AM | Joined: Jan 2004 Posts: 158 Member | | Member Joined: Jan 2004 Posts: 158 | Im not sure how to tell, as far as I know there solid....how can I tell what your talking about, Im pretty sure the lifters are the regular kind.
- Shane
#27599 05/02/2004 2:53 PM | Joined: Mar 2004 Posts: 3,068 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 3,068 | If they are your typical hydraulic lifters, and not solid, go to the hyperformance forum and go to the "adjusting valves" post on 4-27-04. There are a couple of techniques discussed there (including mine). Hope this helps, Scott | | |
#27601 05/04/2004 5:51 AM | Joined: Jan 2004 Posts: 158 Member | | Member Joined: Jan 2004 Posts: 158 | OK, thanks for the help. I guess I will plan on doing this later this week. But I still need a harmonic balancer!!
- Shane
