1 members (NJC),
47
Mod | | | Forums66 Topics128,009 Posts1,055,293 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#26694 07/10/2004 5:20 PM | Joined: Mar 2004 Posts: 31 Member | | Member Joined: Mar 2004 Posts: 31 | where in the engine does the information come from that then the gage it's running hot - the gauge uses bulb indicator it lights up if it is hot or cold - engine 305 or 327 :confused: thanks
jsalchevy63
#26695 07/10/2004 5:24 PM | Joined: May 2003 Posts: 1,271 Shop Shark | | Shop Shark Joined: May 2003 Posts: 1,271 | There's a temperature sender, with a wire connected to the top of it ... it should be found either on the side of your engine-head or in the top of the intake manifold.
~~ Alan Horvath 1954 Chevy PickupSinging his praises in thePassing Lane | | |
#26696 07/10/2004 5:51 PM | Joined: Jul 2004 Posts: 24 Member | | Member Joined: Jul 2004 Posts: 24 | Yeah..some of the older have them on the intake.
Most SBC have them on the head. It could be either side, most of the time they put it on the driverside.
Stella 1970 Monte Carlo 355 1987 Camaro IROC-Z 305 TPI 1955 Chevrolet Second Series GET-R-DONE | | |
#26697 07/10/2004 6:01 PM | Joined: Mar 2001 Posts: 259 Member | | Member Joined: Mar 2001 Posts: 259 | If your not sure if you have the right sender then just turn the key to the on position and have someone look at the gauges while you take the wire off the sender and touch the wire to metal. This will cause the light to turn on.
Joe
#26698 07/10/2004 6:27 PM | Joined: Mar 2004 Posts: 31 Member | | Member Joined: Mar 2004 Posts: 31 | thanks for the info -
jsalchevy63
