5 members (rick46ia, elhippie64, Peggy M, JW51, 1955firstseries), 66 guests, and 2 robots.
Topics128,022
Posts1,055,361
Members48,420
#26694 07/10/2004 5:20 PM
where in the engine does the information come from
that then the gage it's running hot - the gauge uses
bulb indicator it lights up if it is hot or cold - engine
305 or 327 :confused: thanks
jsalchevy63
#26695 07/10/2004 5:24 PM
There's a temperature sender, with a wire connected to the top of it ... it should be found either on the side of your engine-head or in the top of the intake manifold.
~~ Alan Horvath
1954 Chevy Pickup
Singing his praises in the
Passing Lane
#26696 07/10/2004 5:51 PM
7
7 Offline
Yeah..some of the older have them on the intake.
Most SBC have them on the head. It could be either side, most of the time they put it on the driverside.
Stella
1970 Monte Carlo 355
1987 Camaro IROC-Z 305 TPI
1955 Chevrolet Second Series
GET-R-DONE
#26697 07/10/2004 6:01 PM
If your not sure if you have the right sender then just turn the key to the on position and have someone look at the gauges while you take the wire off the sender and touch the wire to metal. This will cause the light to turn on.
Joe
#26698 07/10/2004 6:27 PM
thanks for the info - cool
jsalchevy63
