4 members (Hotrod Lincoln, 1955 1 Series, Stovebolt48, Gray_Ghost), 103 guests, and 3 robots.
Topics128,120
Posts1,056,319
Members48,439
#26687 04/15/2005 10:59 PM
Simple question. What would be necessary to mate up an SM-420 4-speed to a Chevy V8 small block?
Anyone knowledgeable on that combination?
Thanks.
52 GMC 3/4 ton pickup
68 Big Block Vette
68 455 Firebird
#26688 04/15/2005 11:24 PM
a bellhousing and 4 bolts? grin some trucks came from the factory that way in the 60's
#26689 04/16/2005 12:58 AM
Like mine for instance! smile
Brian
P.S. So as to remove some of the "post whore" qualities of my post, I'll mention that if you're switching from an automatic, you'll also need the correct fly wheel, starter, and dust cover.
Brian
#26690 04/16/2005 2:42 AM
I have a '66 C-10 with a factory 327cid with a factory SM420. I also have a '66 C-20 with a factory straight six with a factory SM420. The factory SM420 will bolt directly to a small block Chevy that is set up for a four-on-the-floor manual transmission arrangement.
#26691 04/16/2005 2:51 AM
Did that last year in my truck. Check my webshots. Keep in mind that SM-420 and SM-465 bellhousings are different. The 465 uses a larger center hole than the 420. Found mine on Ebay for something like $20.
"If the women don't find ya handsome, they should at least find ya handy!"
1961 Apache 20 4x4
http://community.webshots.com/album/97352016vHsKNP
#26692 04/16/2005 3:52 AM
I bought two of the correct bellhousing last year. One for $10 at a swap meet, and the other for $25 on eBay. I saw a couple more at the last swap meet I went to.
What year truck are you putting this in? If it is earlier than '54 you will either need a '54-'55 1st type crossmember, or will need to fabricate some adapters to mate the bellhousing to the crossmember.
#26693 04/22/2005 6:56 AM
It's on a '52 3.4 ton. I expected some work anyway to get a small block in it. I was just wondering if SM-420's could be put behind a small block, and what I gather is, that it is possible, providing that I get the right bellhousing.
On e-bay, I wouldn't have known what to look for! It's clear I have a lot more to learn about my own truck!
Is there a good book that I can get on these old trucks?
Thanks.
68 Big Block Vette
68 455 Firebird
