1 members (stoveboltgator), 218 guests, and 0 robots.
Topics128,048
Posts1,055,540
Members48,425
#26494 07/23/2003 11:21 PM
How does a guy go about removing the colum tube from the steering box.I want to reuse the colum and inner shaft so a torch is not a option Thanks in advance for your replies Wayne :confused:
1956 GMC TF 1/2 ton
1955 GMC 500 model (Gumby)
#26495 07/24/2003 4:07 AM
Good luck
#26496 07/24/2003 5:27 AM
'38 Chevy 1-1/2 ton
'49 Chevy 1/2 ton
'54 Chevy 6400 2 ton
'55.2 GMC 3/4 ton
'56 GMC 1-ton
No Room Left in Shop
#26497 07/24/2003 7:27 AM
Wayne, are we to understand that you are fabricating custom steering linkage and only need to keep the stock bits from the firewall to the wheel? If that's the case, I would suggest a pipecutter and patience to trim the outer tube. Once the tube is out of the way you can probably torch the shaft to length.
1955 First Series GMC 250 1-Ton Panel
Mr. Hedgehog - Follow the build
If you can't laugh at yourself, I'll laugh at you.
#26498 07/24/2003 7:59 AM
Thats right hedgehog thats what I am doing thanks for the reply
1956 GMC TF 1/2 ton
