1 members (keithfielder), 129 guests, and 1 robot.
Topics128,162
Posts1,056,938
Members48,458
Fox
Offline
Need help mounting my 350 and 400 tranny in my 50 chev. The Mustang ifs is in and done. I would like to mount the engine. questions though, is it possible to squeeze the engine in without cutting the firewall? If so, is there room up front for the rad? Use the 350 rad? Mount engine directly onto mustang x-member? How low on the x-member should the engine be? anybody out there whose done this PLEASE help. :confused: Thanks.
1970 Chevrolet C10
1950 Chevrolet 1-Ton Dually
"Ole Red Girl"
More pictures here
Parts trucks-
Fox are you going to run the stock fan or go to an electric?
John....38 Chevrolet Panel Delivery
http://community.webshots.com/user/tobytailford
Anonymous
Unregistered
Anonymous
Unregistered
Fox,
There should be no need to cut the firewall. The V8 is shorter than the six that the truck was designed around. I have seen many 350/400 combos put in AD series trucks without a so much as a grind mark on the firewall/toeboard area. I can't comment on your cross member, but you should be able to set your radiator shell in place and use that as a guide when setting the motor and tranny.
Fox
Offline
Probably the stock fan. Is an electric better?
1970 Chevrolet C10
"Ole Red Girl"
More pictures here
Parts trucks-
I was going to say if you are tight for room then you could go to an electric fan and mount it on the front of the radiator. That would probably give you about an extra 4 inches of clearance. But after looking at many of the modified trucks you should be able to put it in with no big mod's to0 the firewall. I wouldn't attach a mount to the MII cross member. A couple of options there, frame rail engine mounts are available at most HR shops or build your own. If you keep the motor mount pin level with the top of the frame rail should give you a good height for the motor. This will probably give about 2-3 inches clearance from the bottom of your engine to the cross member.
And don't forget to check clearances with the HEI in place. I've seen a few jobs that omitted this step. wink
Fred
52 3600
69 C-10
Fox
Offline
Fred what is HEI?
1970 Chevrolet C10
"Ole Red Girl"
More pictures here
Parts trucks-
Z
Z Offline
the LARGE cap electronic distributor used on late model engines.you should mount your engine back as far as possible for best traction and handling.
