| | | Forums66 Topics128,154 Posts1,056,838 Members48,456 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#26469 12/02/2002 2:18 AM | Joined: Apr 2002 Posts: 2,168 A teacher, but always an apprentice. | | A teacher, but always an apprentice. Joined: Apr 2002 Posts: 2,168 | Need help mounting my 350 and 400 tranny in my 50 chev. The Mustang ifs is in and done. I would like to mount the engine. questions though, is it possible to squeeze the engine in without cutting the firewall? If so, is there room up front for the rad? Use the 350 rad? Mount engine directly onto mustang x-member? How low on the x-member should the engine be? anybody out there whose done this PLEASE help. :confused: Thanks. | | |
#26470 12/02/2002 2:56 AM | Joined: Nov 2001 Posts: 58 Member | | Member Joined: Nov 2001 Posts: 58 | Fox are you going to run the stock fan or go to an electric? | | |
#26471 12/02/2002 4:36 AM | | Anonymous Unregistered | | Anonymous Unregistered | Fox,
There should be no need to cut the firewall. The V8 is shorter than the six that the truck was designed around. I have seen many 350/400 combos put in AD series trucks without a so much as a grind mark on the firewall/toeboard area. I can't comment on your cross member, but you should be able to set your radiator shell in place and use that as a guide when setting the motor and tranny. | | |
#26472 12/02/2002 5:22 AM | Joined: Apr 2002 Posts: 2,168 A teacher, but always an apprentice. | | A teacher, but always an apprentice. Joined: Apr 2002 Posts: 2,168 | Probably the stock fan. Is an electric better? | | |
#26473 12/03/2002 4:41 AM | Joined: Nov 2001 Posts: 58 Member | | Member Joined: Nov 2001 Posts: 58 | I was going to say if you are tight for room then you could go to an electric fan and mount it on the front of the radiator. That would probably give you about an extra 4 inches of clearance. But after looking at many of the modified trucks you should be able to put it in with no big mod's to0 the firewall. I wouldn't attach a mount to the MII cross member. A couple of options there, frame rail engine mounts are available at most HR shops or build your own. If you keep the motor mount pin level with the top of the frame rail should give you a good height for the motor. This will probably give about 2-3 inches clearance from the bottom of your engine to the cross member. | | |
#26474 12/03/2002 5:59 AM | Joined: Jun 2000 Posts: 2,773 'Bolter | | 'Bolter Joined: Jun 2000 Posts: 2,773 | And don't forget to check clearances with the HEI in place. I've seen a few jobs that omitted this step.
Fred 52 3600 69 C-10
#26475 12/07/2002 10:23 PM | Joined: Apr 2002 Posts: 2,168 A teacher, but always an apprentice. | | A teacher, but always an apprentice. Joined: Apr 2002 Posts: 2,168 | | | |
#26476 12/08/2002 2:34 AM | Joined: Jan 2001 Posts: 613 Member | | Member Joined: Jan 2001 Posts: 613 | the LARGE cap electronic distributor used on late model engines.you should mount your engine back as far as possible for best traction and handling. | | |
