7 members (3B, Phak1, 1955 1 Series, Gib70, Joe H, KEVINSKI, 1 invisible),
133
Mod | | | Forums66 Topics128,092 Posts1,056,451 Members48,443 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2006 Posts: 63 'Bolter | | 'Bolter Joined: May 2006 Posts: 63 | Okay, I have been hearing different stories. In a 1950 1/2 or 3/4 ton panel, There was no difference in them other than the running gear, correct?
In a 1ton, Is there an approximate 1 inch difference in size in the grill, fenders and dash?
If there is, What would be a good indicator without measuring?
Would the rear barn doors be any different aswell?
The reason I am asking is because I found a perfectly good panel at a local yard, And I think it is a 1 ton. It is longer in length than a half ton and has 8 lug wheels.
It is so clean and rust free, That it could possibly be driven out of there. But due to it being in a yard, They would only sell it in three parts meaning cutting it in sections.
You would not believe how clean this panel is.
Any help??
Thanks Javier | | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | A 1 ton should have a 137" wheel base. The front sheetmetal including grill is the same as the smaller trucks. I believe the dash is the same up through at least 2.5 ton. Grigg | | | | | Joined: Oct 2005 Posts: 275 Shop Shark | | Shop Shark Joined: Oct 2005 Posts: 275 | Are you serious they would have cut it up to sell it? If so that's absolutely ridiculous. What a waste of a good body.
38 original 48 panel 59 stepside 46 in the back forty
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | There was no 3/4 ton Chevrolet Panel in 1950.
Grigg's information is correct. The 1/2 ton and 1 ton panel's dashes were the same. Rear doors would have been the same.
Beg them not to cut it up. | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | buy the panel...then buy the guys off to let you take it out complete. PLEASE. If you were closer I would go with you to get it at NIGHT  | | | | | Joined: Nov 2001 Posts: 438 'Bolter | | 'Bolter Joined: Nov 2001 Posts: 438 | tell them you will take off the body from the frame and then cut the frame in half if that is last resort
Opportunity is missed by most people because it is dressed in overalls and looks like work. - Thomas Edison Things may come to those who wait...but only the things left by those who hustle."-Abraham Lincoln
| | | | | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | They must not have a title for it, and therefore they can not sell it as a complete vehicle. While I understand the desire not to see it cut up, it may be real hard to get proper paperwork for it.
Buy the barn doors and rear fenders off of it ASAP.
Then ask them if they can sell it at an auction like would happen with an abandoned car. I don't know if that would work in CA but in Washington that might be a way to get it sold with paper. Just make sure you show up at the auction with enough money!
1955 1st GMC Suburban | 1954 GMC 250 trailer puller project | 1954 GMC 250 Hydra-Matic | 1954 Chevy 3100 . 1947 Chevy COE | and more... It's true. I really don't do anything but browse the Internet looking for trouble... | | | | | Joined: Oct 2004 Posts: 348 Shop Shark | | Shop Shark Joined: Oct 2004 Posts: 348 | you can buy junked cars contact chp for the process on how to title them | | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | I wonder if they would go for separating the front clip and selling you the two pieces. That is a very special find.
The 1 Ton has a thicker front bumper and the bumper supports are much shorter as it is closer to the end of the frame. | | | | | Joined: Nov 2006 Posts: 87 Member | | Member Joined: Nov 2006 Posts: 87 | Hopefully there is a way to avoid cutting it up.
Toxictiki
'59 Apache 3100 panel (235) '51 Chevy Fleetline Deluxe (216) '48 Binder KB-1 (flathead 6) '77 Cadillac DeVille (425 donor)
"Once I was 'Chairman of the Bored' then I bought a Stovebolt."
| | | | | Joined: Nov 2001 Posts: 1,519 'Bolter | | 'Bolter Joined: Nov 2001 Posts: 1,519 | If they insist on selling it in 3 parts,,buy the front end,,then the doors,,then the body. Then go to d.m.v. and register it as abandoned on one of your "rental properties",with no plates and paperwork. Good Luck, Marty | | | | | Joined: Mar 2007 Posts: 4,215 Moderator | | Moderator Joined: Mar 2007 Posts: 4,215 | I'll sign a petition not to cut it up. What are they thinking??!! | | | | | Joined: May 2006 Posts: 63 'Bolter | | 'Bolter Joined: May 2006 Posts: 63 | I talked to the guy about the panel today. He stated that they will try to make it into a historical vehicle therefore avoiding the torch. And I would be able to get it out in one piece. If that does not fly we went over as to how to get it out in three parts.
I took some of your advice with me and gave it to him like this: First part would consist of the whole front clip including the engine and front axel, hub to hub. Second would consist of all the doors, running boards, both seats and any other interior components. Third would leave the whole body off the frame and on to my trailer. The frame would have to stay. I tried to convince him of making the whole frame with the axles and engine as one part. I think he might go for it. He too does not want to see it cut up, But he is just following protocol
Question is "What am I going to do with a 1ton body if the frame stays"? I know I will use the rear barn doors (they have the deluxe ss),the driver and pass doors w/ss,grill,fenders (holes and clips for the seargent strips but no strips) and some of the interior components. The seats are spoken for by a friend.
Would any body need a 1 ton panel body? | | | | | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | I want it. Ship it to me!
1955 1st GMC Suburban | 1954 GMC 250 trailer puller project | 1954 GMC 250 Hydra-Matic | 1954 Chevy 3100 . 1947 Chevy COE | and more... It's true. I really don't do anything but browse the Internet looking for trouble... | | | | | Joined: Nov 2001 Posts: 1,519 'Bolter | | 'Bolter Joined: Nov 2001 Posts: 1,519 | | | |
