9 members (Tronman, Otto Skorzeny, Hotrod Lincoln, tclederman, Bill Hanlon, carbking, 49choptop, Guitplayer, John L.),
155
Mod | | | Forums66 Topics128,042 Posts1,055,501 Members48,424 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | Welcome to the Stovebolt!
I don't know exactly how to solve your problem.
I think I'd loosen the body bolts and lift the body a little. If I remember right the floors are installed before the body is put on the frame so it may not be possible to get the planks out without cutting the planks or lifting the body.
1955 1st GMC Suburban | 1954 GMC 250 trailer puller project | 1954 GMC 250 Hydra-Matic | 1954 Chevy 3100 . 1947 Chevy COE | and more... It's true. I really don't do anything but browse the Internet looking for trouble... | | | | | Joined: Jul 2006 Posts: 53 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2006 Posts: 53 | I read the thread about the suburban body mounts. Is it the same for Panels? How many mounts total should I be looking for? There are the obvious two at the cab front, but I am having trouble locating the others.
Thanks for the quick response also. This forum is a God send. I didn't expect to find anything like it. All you Suburban guys are making me jealous! | | | | | Joined: Oct 2005 Posts: 4,249 "Hey! I sound like Darth Vader!! | | "Hey! I sound like Darth Vader!! Joined: Oct 2005 Posts: 4,249 | Two right behind the doors. Two in front of the rear axle, two behind and two at the very rear. | | | | | Joined: Oct 2005 Posts: 4,249 "Hey! I sound like Darth Vader!! | | "Hey! I sound like Darth Vader!! Joined: Oct 2005 Posts: 4,249 | BTW, you should be able to see all the bolt heads from up top. | | | | | Joined: Jul 2006 Posts: 53 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2006 Posts: 53 | Thanks MN - By the way, even if I don't remove the cab, would you guys recommend replacing the mounts? | | | | | Joined: Oct 2005 Posts: 4,249 "Hey! I sound like Darth Vader!! | | "Hey! I sound like Darth Vader!! Joined: Oct 2005 Posts: 4,249 | After 50+ years, those mounts have been compressing, wearing and getting squished. I'd replace 'em. | | | | | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 |
1955 1st GMC Suburban | 1954 GMC 250 trailer puller project | 1954 GMC 250 Hydra-Matic | 1954 Chevy 3100 . 1947 Chevy COE | and more... It's true. I really don't do anything but browse the Internet looking for trouble... | | | | | Joined: Jul 2006 Posts: 53 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2006 Posts: 53 | Ok, so the front mounts are obviously a piece of cake. As for mounts 3&4 and 5&6, these are the wood blocks that are under the metal bars running under the rear floor? those account for 50% of what is holding my body to the frame? Scary! I'm having trouble locating the most rear mounts.
Also, is the aftermarket mount kit wood blocks, or are they updated with rubber or something? I'd be interested to know if there is a suitable replacement for those carriage bolts. I ended up grinding off the tops of about 3/4 of them because the square holes were rounded out. Perhaps a carriage bolt with an allen or star center for holding them while backing out those annoying square nuts? I guess I'm really asking if anyone offers a high quality aftermarket bed fastener kit? Thats a lot of pieces to locate individually. Thanks all!
trevor | | | | | Joined: Oct 2005 Posts: 4,249 "Hey! I sound like Darth Vader!! | | "Hey! I sound like Darth Vader!! Joined: Oct 2005 Posts: 4,249 | The only one I know of who sells a Suburban / Panel body mount kit is Chevy Duty ( now American Classics?) They come with the wood blocks. I suppose, if you really wanted, you could put in some steel tubing blocks. As for removal of the bolts, I found the easiest way was to ping the center of the head with a center punch, use three bits to progressively move up in size until a 3/8" bit broke the head off. No grinding, no rounding of the washer. I suppose you can put a different bolt in instead of the carriage bolt. Don't know if they make button head allen drives that big though. | | | | | Joined: Oct 2005 Posts: 4,249 "Hey! I sound like Darth Vader!! | | "Hey! I sound like Darth Vader!! Joined: Oct 2005 Posts: 4,249 | My bad. Jim Carter. Part # CBK156 | | | | | Joined: Jul 2006 Posts: 53 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2006 Posts: 53 | When I hear center punch, i think leather tooling. What tool are you refering to MN? Thanks for the assistance! | | | | | Joined: Mar 2005 Posts: 267 Shop Shark | | Shop Shark Joined: Mar 2005 Posts: 267 | oksoda .i got your e-mail. it looks like the wise ones (  or :rolleyes: )have you well in hand. tom
I don't suffer from insanity, I enjoy every minute of it!
| | | | | Joined: Oct 2005 Posts: 4,249 "Hey! I sound like Darth Vader!! | | "Hey! I sound like Darth Vader!! Joined: Oct 2005 Posts: 4,249 | Originally posted by OKSoda: When I hear center punch, i think leather tooling. What tool are you refering to MN? Thanks for the assistance! Like a nail punch. A punch with a point. For easy centering of your drill bit. | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | speaking of bed mounts I thought I would throw in this idea to you all. When doing my 37 I did use the wood blocks (nice idea though to use metal tubing) I found an old fire hose from a volunteer fire dept. These have a couple layers of "fabric" on the outside of a "rubber" inside. They make very good pads or cushions to sit the blocks on and it will help to cut down on the noise or squeaking etc. Anyway, it works great for me and I plan to do the same on my 52 panel. | | | | | Joined: Jul 2006 Posts: 53 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2006 Posts: 53 | Thanks everyone! Got all the body mounts out and used a floor jack to get that cab end up a bit and the boards slid right out. Also, looks like I just decided to go frame-off. Seeing the body up like that sold it for me. | | | | | Joined: Nov 2001 Posts: 438 'Bolter | | 'Bolter Joined: Nov 2001 Posts: 438 | OKSoda If you decide to pull the body off do a search and reread past threads on the subject. Not hard to do but if you dont have a lift handy it takes some planning to be done safely. One word of caution though is once you roll out the chassis your mind says while I have it out i should a) sandblast and paint/powdercoat frame,b) if I do that I will need new brake and fuel lines, c)since I am doing all this lets rebuild or upgrade engine,transmisson, drivetrain d)a IFS would be nice and ..... Please don't ask me how I know this!! Good luck
Opportunity is missed by most people because it is dressed in overalls and looks like work. - Thomas Edison Things may come to those who wait...but only the things left by those who hustle."-Abraham Lincoln
