6 members (klhansen, GRNHydra, Mike Roache, Maybellene, 6inarow, 1 invisible), 138 guests, and 2 robots.
Topics128,035
Posts1,055,552
Members48,425
#24541 04/28/2005 4:30 AM
Junior Member
Junior Member
Hey guys i replaced my spark plugs and distrobutor cap and that stuff then when i got in and started it it ran good but the genartor light stays on now ? what would cause this ? thank you for your help.
life rolls on a?
Are you sure the generator is charging?
Tab Offline
Check the belt tension. Did you knock a wire loose? Does it stay on at all rpm or just idle?
delete my account and pictures
As Tab says, check for a loose wire you might have knocked off. If not, it's the generator gone bad or voltage regulator. Cecil.........
Junior Member
Junior Member
thaNKS IT JUST FIXED ITS SELF IT WIRED
life rolls on a?
