| | | Forums66 Topics128,049 Posts1,055,548 Members48,425 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#24541 04/28/2005 4:30 AM | Joined: Apr 2005 Posts: 6 Junior Member | | Junior Member Joined: Apr 2005 Posts: 6 | Hey guys i replaced my spark plugs and distrobutor cap and that stuff then when i got in and started it it ran good but the genartor light stays on now ? what would cause this ? thank you for your help.
life rolls on a?
#24542 04/30/2005 1:10 PM | Joined: Dec 2003 Posts: 1,144 'Bolter | | 'Bolter Joined: Dec 2003 Posts: 1,144 | Are you sure the generator is charging? | | |
#24543 05/01/2005 2:52 AM | Joined: Jan 2002 Posts: 622 Member | | Member Joined: Jan 2002 Posts: 622 | Check the belt tension. Did you knock a wire loose? Does it stay on at all rpm or just idle?
delete my account and pictures
#24544 05/01/2005 5:11 AM | Joined: Jul 2003 Posts: 586 Shop Shark | | Shop Shark Joined: Jul 2003 Posts: 586 | As Tab says, check for a loose wire you might have knocked off. If not, it's the generator gone bad or voltage regulator. Cecil......... | | |
#24545 05/02/2005 4:03 AM | Joined: Apr 2005 Posts: 6 Junior Member | | Junior Member Joined: Apr 2005 Posts: 6 | thaNKS IT JUST FIXED ITS SELF IT WIRED
life rolls on a?
