1 members (baldeagle), 158 guests, and 2 robots.
Topics128,110
Posts1,056,241
Members48,437
#242070 10/10/2007 9:00 AM
Does anyone know where I can find rear axile bumpers for a 3/4 ton special?
Thanks James
If it was easy, everybody would be doing it.
#242071 10/10/2007 1:56 PM
need more input..
1951 3800
-hotshoe
#242072 10/10/2007 6:15 PM
the rubber piece that mounts to the frame above the rear end, to protect the rear end from hitting the frame.
#242073 10/10/2007 8:21 PM
Are you looking for original or just a replacement? Truck year helps if you want original.
My 1953 Chevrolet
1947.1 Gallery
#242074 10/10/2007 10:19 PM
Sorry i forgot the year, it's a 41 and original or replacement is fine.
#242075 10/11/2007 2:52 AM
FYI - hey are called bump-stops
#242076 10/11/2007 5:52 PM
O.K. bump-stops, do you know where I can find some for a 41 3/4 ton special?
#242077 10/11/2007 6:21 PM
Most of the vendors carry them. I have some I recieved as an error that are for the later 47-54 years I can send you a pic if your interested?
Jeff
My 1953 Chevrolet
1947.1 Gallery
#242078 10/11/2007 11:02 PM
I have looked for them, but I can't find my syle, mine are rectangular shape that screw (2) into the bottom of the hump of my frame. The vendors that i have checked out only carry the front &/or the rear for 1/2 ton trucks.
James
#242079 10/14/2007 3:29 AM
Too bad I can't seem to find any pictures of them on the internet, but ford rangers from the last 10-15 years have nice little rectangle rear axle bumpers that go through a hole in the frame and are tightened on with a nut on one side.
cannot imagine they cost much.
#242080 10/15/2007 5:09 PM
Thanks Colin, I will check that out, I nwas also planning to go thru some truck catalogs to see if I could find some comparable. There has to be some out there.
James
#242081 10/15/2007 8:22 PM
James"
Please post what you find out. I also need a pair for a '41 3/4 ton
1941 Chevy Master 3/4-Ton
More images in the Bolt Bucket
Born to fish, the truck is only a hobby.
#242082 10/15/2007 8:28 PM
Quote
Boy Jim, you had to go thru a bunch of sh++ to get a straight answer on that one. grin
#242083 10/17/2007 6:51 PM
Will do Kip, amen to that Gazim
