| | | Forums66 Topics128,077 Posts1,056,013 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2005 Posts: 103 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2005 Posts: 103 | Does anyone know where I can find rear axile bumpers for a 3/4 ton special?
Thanks James
If it was easy, everybody would be doing it.
| | | | | Joined: Jul 2006 Posts: 707 Shop Shark | | Shop Shark Joined: Jul 2006 Posts: 707 | 1951 3800 Be the change you want to see. -hotshoe
| | | | | Joined: Dec 2005 Posts: 103 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2005 Posts: 103 | the rubber piece that mounts to the frame above the rear end, to protect the rear end from hitting the frame.
| | | | | Joined: Feb 2006 Posts: 1,867 Shop Shark | | Shop Shark Joined: Feb 2006 Posts: 1,867 | Are you looking for original or just a replacement? Truck year helps if you want original. | | | | | Joined: Dec 2005 Posts: 103 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2005 Posts: 103 | Sorry i forgot the year, it's a 41 and original or replacement is fine.
| | | | | Joined: Aug 2007 Posts: 1,859 Grumpy old guy playing with trucks, cars, and boats | | Grumpy old guy playing with trucks, cars, and boats Joined: Aug 2007 Posts: 1,859 | FYI - hey are called bump-stops
| | | | | Joined: Dec 2005 Posts: 103 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2005 Posts: 103 | O.K. bump-stops, do you know where I can find some for a 41 3/4 ton special?
| | | | | Joined: Feb 2006 Posts: 1,867 Shop Shark | | Shop Shark Joined: Feb 2006 Posts: 1,867 | Most of the vendors carry them. I have some I recieved as an error that are for the later 47-54 years I can send you a pic if your interested?
Jeff | | | | | Joined: Dec 2005 Posts: 103 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2005 Posts: 103 | I have looked for them, but I can't find my syle, mine are rectangular shape that screw (2) into the bottom of the hump of my frame. The vendors that i have checked out only carry the front &/or the rear for 1/2 ton trucks.
James
| | | | | Joined: Apr 2001 Posts: 439 Shop Shark | | Shop Shark Joined: Apr 2001 Posts: 439 | Too bad I can't seem to find any pictures of them on the internet, but ford rangers from the last 10-15 years have nice little rectangle rear axle bumpers that go through a hole in the frame and are tightened on with a nut on one side. cannot imagine they cost much. | | | | | Joined: Dec 2005 Posts: 103 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2005 Posts: 103 | Thanks Colin, I will check that out, I nwas also planning to go thru some truck catalogs to see if I could find some comparable. There has to be some out there.
James
| | | | | Joined: Nov 2005 Posts: 1,048 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 1,048 | James"
Please post what you find out. I also need a pair for a '41 3/4 ton | | | | | Joined: Jun 2005 Posts: 1,756 Shop Shark | | Shop Shark Joined: Jun 2005 Posts: 1,756 | Originally posted by James B: O.K. bump-stops, do you know where I can find some for a 41 3/4 ton special? Boy Jim, you had to go thru a bunch of sh++ to get a straight answer on that one.  | | | | | Joined: Dec 2005 Posts: 103 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2005 Posts: 103 | Will do Kip, amen to that Gazim
