0 members (),
196
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,081 Posts1,056,078 Members48,434 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2005 Posts: 531 Shop Shark | | Shop Shark Joined: Feb 2005 Posts: 531 | I needed new pipes on my 56 1/2 ton and when I went to a shop and did the pricing I decided on stainless pipes and a stainless muffler... cost $450 installed. I figured that because mine is a year-round daily driver the extra $$ would be worth it in the long run.
Here's my question... when I got home, I put a magnet to the pipes and it sticks. I thought a magnet wouldn't stick to stainless?? Any metal guys out there that can enlighten me?? Or did I get screwed?
Thanks! | | | | | Joined: Dec 2003 Posts: 1,554 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 1,554 | You are right on the magnet. | | | | | Joined: Mar 2006 Posts: 1,703 Shop Shark | | Shop Shark Joined: Mar 2006 Posts: 1,703 | Smells Fishy ! wasnt S.S. coating ???? | | | | | Joined: Jun 2006 Posts: 204 Shop Shark | | Shop Shark Joined: Jun 2006 Posts: 204 | It depends on the grade of stainless. 300 series stainless has nickel and chromium content and is non magnetic. 400 series stainless has just chromium and is magnetic. So it really depends on the grade. I am not familiar with what is used in exhaust systems, I am sure someone else will chime in. Here is a link with some FAQ's about stainless steel: http://www.ssina.com/faq/index.html A little noodling around on the web came up with 400 grade stainless being used in a lot of stainless systems, with the 304 stainless beign a "premium" exhaust. One site showed the 304 stainless exhaust for a Silverado at about $800, plus shipping not including labor. but cliamed a 1.0 million mile warranty. Mike My old truck's still running good, my ticker's ticking like they say it should, I got supper in the oven, a good woman's loving, and even my bad days aint that bad...Yeah, I'm a lucky man! 1953 Chevy 3100 Shortbed1965 C-30 Panel Truck 1963 C-20 Long/Fleet Pick-up California Black Plate
| | | | | Joined: Apr 2005 Posts: 261 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2005 Posts: 261 | 65PanelMike is correct some grades of stainless steel will rust. Take a magnet with you next time your looking a outdoor grilles you will find the cheaper brands use the lower grade of stainless that are magnetic and will rust.
34 & 35 trucks are the greatest
| | | | | Joined: Dec 2005 Posts: 1,026 'Bolter | | 'Bolter Joined: Dec 2005 Posts: 1,026 | Realistically, how much longer will a stainless system last?
Robert C. If it's true what they say, "You learn from your mistakes," I'm a Genius in the making. 1950 3600 | | | | | Joined: Dec 2006 Posts: 720 'Bolter | | 'Bolter Joined: Dec 2006 Posts: 720 | There should be some info printed avery few feet on the pipe. Look up the number that is on there and it will tell you what kind of metal and what poperties it has. SS pipes that are more prone to corrosion will still greatly outlast steel pipe or aluminized steel pipes regardless. they corrode at a slower rate, and on a daily driver the water in & on the pipes will get burnt out regularly. it's the vehicles that see more moisture than driving that have the real issues with corrosion. 1956 GMC 370 dump " 'Tater "1970 VW Volksrod "the Black Bomber" 2007 Chevy Avalanche 2020 Jeep Cherokee Trailhawk, 2005 Harley Davidson FLHTCUI I dig all cars, old and new, whether they were hammered out of American iron, German steel, or Japanese tin cans. Being unable to appreciate them all is missing out on a world of great things. But thats just MY opinion! :P
| | | | | Joined: Apr 2007 Posts: 147 Shop Shark | | Shop Shark Joined: Apr 2007 Posts: 147 | Don't be too concerned, I have a Bosell stainless exhaust system on one of my cars and the first one lasted over 12 years in the worst of conditions. My second one has been on the car for approximately 7 years and shows no signs of wear. Stainless is better, I just went out and put a magnet on the system and it is magnetic. Bob
55 Cameo 396 TH 400 with overdrive 65 Caliente conv 67 BB Caliente conv 67 Mercury 1 Ton 76 GMC 3/4 ton 454ci 84 Buick Turbo Regal
| | | | | Joined: Feb 2005 Posts: 531 Shop Shark | | Shop Shark Joined: Feb 2005 Posts: 531 | Thanks for the feedback... I'm feeling less screwed! : ) | | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | I hear that as far as a practical stainless system the 400 series is better, it is less prone to cracking at the weld joints (if there are any). While the 300 series does tend to eventually crack it holds a better polish longer.
When I get there, I'll use 409 stainless for my truck as I will have lots of welding to do and it won't be polished.
Grigg | | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | OK so where do you get the stainless pipes? Do the muffler shops carry them. I talked to a guy who told me he had to buy the pipes and take them to several muffler shops before he found one that would install them.
~Jim
| | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | In my case I will buy a bunch of bends in 5" stainless exhaust pipe, then cut and TIG weld them together to make what I need. If I can find some left overs from an exhaust manufacturer that would be great, dig through a scrap bin and pull out the 5" stainless stuff. So far I have not found any deals on assorted left overs.
Grigg | | | | | Joined: Feb 2001 Posts: 198 Shop Shark | | Shop Shark Joined: Feb 2001 Posts: 198 | Took my '98 Exploder to the muffler shop cause the exhaust was rattling. Manager said the car companies are putting stainless exhaust on, but the hangers are still steel. He's been replacing perfectly good exhaust systems because of the missing hangers. He welded up mine.. but it was ugly..It's under the truck where no one looks.
Attitude - The difference between an adventure and an ordeal! Deja Moo - The feeling you've heard this bull**** before! '63 Chev Fleetside Longbox 'Rusto-rod' 'Big Red' '69 or'70 or ? Mantaray DuneBuggy
| | | | | Joined: Feb 2005 Posts: 531 Shop Shark | | Shop Shark Joined: Feb 2005 Posts: 531 | Big Chevy - I went to a custom muffler shop for mine. It was like a fast food place - took about 30 minutes for them to cut, bend and weld it all up. I doubt the chains have them but I don't know for sure.
By the way, notice in your profile you're into Scouting... 45 year vet here. | | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | Yeah Larry, I'm a retired Scoutmaster but active in OA and staffing the National Jambo. My first year at camp was 1954. Guess I'll add something relative to tailpipes. I wanted to have the pipes installed before the cab was on but I've had folks here on the Bolt suggest the pipe boys prefer to work underneath so they can keep from bumping the body.
~Jim
| | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | You should have no exhaust to body interference on an AD truck with 6 cylinder, the exhaust comes no where near the cab. Going over the rear axle and under the bed is as close as it gets.
Grigg | | |
