7 members (mick53, Bill Hanlon, klhansen, mason86, Otto Skorzeny, Hawkman, festerhairball),
76
Mod | | | Forums66 Topics128,069 Posts1,055,886 Members48,428 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | I have been trying to decide whether to use two point or three point seatbelts in my AD one Ton. Here is my problem. Quite a few three point setups that I have driven with will lockup when going over a good bump. Mostly this isn't a problem but in my 1 Ton, if this happened in an emergency while trying to access the handbrake, I would be out of luck. What do you think about this dilemma? | | | | | Joined: Feb 2001 Posts: 4,095 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 4,095 | think back to how many times this has been necessary and then decide. iam putting in seats with built in three point because i think it is very good thing. Ron
Ron, The Computer Greek I love therefore I am.1954 3100 Chevy truckIn the Gallery 2017 Buick Encore See more pix1960 MGA Roadster Sold 7/18/2017
| | | | | Joined: Jun 2006 Posts: 272 Shop Shark | | Shop Shark Joined: Jun 2006 Posts: 272 | Is the inertia system on after market belts as sensitive to bumps as the electric assist units on today's newer vehicles?
1948 AD Pickup
| | | | | Joined: Jun 2005 Posts: 887 Shop Shark | | Shop Shark Joined: Jun 2005 Posts: 887 | With a metal dash and non-collapsing steering column, I went with 3 point belts to avoid a bump on my head (or a pssanger's) whenever I have to slam on the brakes.
| | | | | Joined: Oct 2001 Posts: 3,458 Extreme Gabster | | Extreme Gabster Joined: Oct 2001 Posts: 3,458 | If your hydraulic brakes fail you won't be getting that much force on the seatbelt tensioners. I wouldn't sweat it, use the 3 points.
Paint & Body Shop moderator A lone amateur built the Ark. A large group of professionals built the Titanic. | | | | | Joined: Jul 2005 Posts: 2,031 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 2,031 |
Jim & Caroline The highway is for gamblers, better use your good sense." Gooday-that's my 1¢ answer due to the lousy economy ~ cause I ain't got - no . mo . doe Every Shaver | Now Can Snore | Six More Minutes | Than Before ... | Half A Pound for Half a Dollar | Spread On Thin | Above the Collar || BURMA-SHAVE
| | | | | Joined: Jun 2007 Posts: 17 New Guy | | New Guy Joined: Jun 2007 Posts: 17 | Are you keeping your Bolt stock? If not, you could find yourself a couple of front bucket seats out of a 1999 and up Serria/Silverado. Both of these have the seat belts as part of the seat. This way you don't have to worry about fabing up upper belt mounting points in you cab. Plus the have better lumbar support than your old bench probably has. | | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | Nthstr, I am keeping it stock but if I were to change the seats, it would definitely be for the lumbar support. Thanks for that suggestion. | | | | | Joined: Sep 2005 Posts: 1,028 'Bolter | | 'Bolter Joined: Sep 2005 Posts: 1,028 | 3 point is the way to go. You wont look pretty with that steering column impression in your chest. | | |
